1980 Cutlass PCV valve
Hi, I have a 1980 cutlass supreme coupe with the 3.8 v6. I want to check/replace the pvc valve, not the one on the valve cover, but the one which runs from just below the carburetor to the rear section on the intake manifold. I tried to remove it from the grommet, but I get some resistance as if maybe it’s threaded in, it is a bit loose. Can I just pull it out with a little force, I just do not want to do something wrong and regret it?
Thank-you
Thank-you
Almond900
Feb 26, 2016 02:56 AM
