1980 Cutlass PCV valve
Old Jun 30, 2020 | 12:50 PM
imcutlass's Avatar
Hi, I have a 1980 cutlass supreme coupe with the 3.8 v6. I want to check/replace the pvc valve, not the one on the valve cover, but the one which runs from just below the carburetor to the rear section on the intake manifold. I tried to remove it from the grommet, but I get some resistance as if maybe it’s threaded in, it is a bit loose. Can I just pull it out with a little force, I just do not want to do something wrong and regret it?
Thank-you
Old Jun 30, 2020 | 02:54 PM
Just pull on it. Be careful that the grommet is likely hard and brittle, which is why it's hard to get out.
Old Jun 30, 2020 | 02:59 PM
Spray it down with wd40 and wiggle it around first.
louie
Mar 4, 2020 04:27 PM
Stephen0523
Aug 2, 2017 03:33 AM
Almond900
Feb 26, 2016 02:56 AM
tgilligan
Mar 22, 2013 01:35 PM
abram
Nov 10, 2009 10:18 AM
