U joint U bolts
Old Nov 14, 2024 | 04:55 PM
mattking's Avatar
U joint U bolts
I don’t know if the driveline forum may be a better place. If so feel free to move this.
I got a new driveshaft made for my 64 cutlass but cannot find u bolts for the yoke at the differential. I have tried a spicer 2-94-28x. It was too narrow on the centerline for the bolts. I checked the parts place and they sold me their part su1310z. Which they say is all years with the 1.125 cap size. It is also too narrow and seems to be the same dimensions as the spicer part.
I measure the caps on the driveshaft at 1.125 and they seem to fit well if a little snug in the yoke. The u joint on the shaft has the inside clips for retention. I measure the centerline of the holes to be about 1.5” but, it could be 1.45 or 1.55 maybe. But it really looks like 1.5”. Is there a source for these? Is it safe to use old ones and if so does anyone have any?
If not how do I move forward? Replacing the yoke with something that has available u bolts?
Old Nov 14, 2024 | 05:31 PM
The original part number is 1357233. AMK sells them. So do these guys.
Old Nov 14, 2024 | 05:58 PM
mattking's Avatar
Joe- Thanks. I just put an order In. I’m going to look more at amk tomorrow. I may need even more stuff from them.
Old Nov 15, 2024 | 06:14 AM
newmexguy's Avatar
There are two well known axle builders in the Midwest on the sites. Trick (Brian) Erie PA, and Monzaz (Jim) in Ohio. Suspect they have sizable quantities of miscellaneous driveline hardware.
Old Nov 21, 2024 | 08:03 AM
mattking's Avatar
Just a quick update: The ones from AMK fit well.
Thanks everyone for the help.
Old Nov 21, 2024 | 11:27 AM
Glad that worked for you. Most mainstream parts suppliers assume Chevy means all of GM.
cjsdad
Drivetrain/Differentials
Apr 30, 2022 10:26 PM
Allan R
May 26, 2016 06:24 PM
Mr Nick
Feb 18, 2014 03:10 PM
jims2000lt
May 11, 2013 06:18 AM
costpenn
47
Apr 16, 2013 10:30 AM
