U-Joint strap for type-O rear end
Old Feb 16, 2014 | 01:50 PM
Mr Nick's Avatar
Checking two sources online, they show MOOG 53010 as the correct strap and bolt kit, but my rear end uses U-bolts that pass thru the yoke and are retained by nuts. (Edited)
What application do I look up, or better yet know the correct replacement part number?
Old Feb 17, 2014 | 10:07 AM
Question: How would you screw both ends of a threaded U bolt into the yoke?
There are two different u-joint retainers:
1 - u-bolt with threaded ends, passes through hole in yoke and uses nuts/washers on threaded end of u-bolt
2 - strap with bolts that thread into yoke
So, you need either straps/bolts or threaded u-bolts/nuts, depending upon which style yoke you have.
Old Feb 17, 2014 | 02:08 PM
Mr Nick's Avatar
You're right, I explained that wrong. My mistake.
I have U-bolts that pass thru the yoke, and are retained by nuts. Like picture one.
Old Feb 17, 2014 | 10:57 PM
The O-Type 12 bolts have the u-bolt/nut style and the '71-up 10 bolts have the strap/bolt style. So you are looking for the u-bolt style for a '67-'70 Olds O-Type.
Supercars unlimited has them listed:
http://www.supercarsunlimited.com/64...29.-d2389.aspx
Rock Auto has a listing for u-bolts but theirs says 8.2" diff and has some notes about fitting 3R yoke only. I am not sure what that means.
Old Feb 18, 2014 | 07:49 AM
monzaz's Avatar
U-bolt u-joint hold downs
A lot of people will get the 8.2 Chevy mixed up with the 8.2 BOP
BOP is Mechanics R3 which is a 1 1/8" cup (wider u-bolts ) The Chevy 1310 u-bolts are 1 1/16" and will not fit the BOP yoke. I have seen guys spread them to fit ....!!! THIS IS WRONG do not do this. They should just slide right in - Jim
JD
Old Feb 18, 2014 | 08:23 AM
507OLDS's Avatar
Part # 81002 in those red HELP packages at the parts store.You might have to order them,but that is the correct number.
Old Feb 18, 2014 | 10:42 AM
Brian, thanks for that info! I'm gonna add it to my O-Type part numbers spreadsheet.
Amazon shows to have them for $6.45:
Dorman HELP! 81002 U-Joint Repair Kit : Amazon.com : Automotive Dorman HELP! 81002 U-Joint Repair Kit : Amazon.com : Automotive
JD
So does the 8.2 BOP u-bolt fit the O-Type yoke? Below is the info from Rock Auto's web site for the 1969 Cutlass listing:
USA STANDARD GEAR Part # USA41186 U/Bolt Kit for 8.2" BOP, Mechanics 3R aftermarket Yoke only.
Rear Diff; RWD; GM 8.2" Rear for Buick, Oldsmobile & Pontiac
Old Feb 18, 2014 | 03:10 PM
Mr Nick's Avatar
Great info, thanks guys.
Topless72
Nov 22, 2020 11:01 AM
350TurBRO
Sep 12, 2014 11:52 AM
cluelesscutlass
Aug 18, 2011 01:56 AM
Aron Nance
Drivetrain/Differentials
Sep 14, 2010 05:37 AM
Qwik71442
May 26, 2010 10:58 AM
