Tires for a '72 Cutlass
Old Sep 15, 2013 | 02:56 PM
Winger67's Avatar
1972 Cutlass Convertible
I think the BF Goodrich Eagle STs on the car are from '82. Probably time for new tires. BF Goodrich Radial T/A the way to go or is there another recommendation with white lettering? Any rubbing with 245/60R15?
Old Sep 15, 2013 | 03:01 PM
OLD SKL 69's Avatar
GM Enthusiast
Radial T/A's always look good and would be my first choice. I have 215/70 in the front, and 245/60 in the rear with no issues. Not sure about bigger tires on the front, maybe someone else will chime in.
Cooper also makes a nice white letter tire.
Old Sep 15, 2013 | 03:42 PM
Eagle ST tires were made by the people with the blimp, not BFG.
In any case, I've run 255/60-15 BFGs on all four corners of my 69 H/O on the stock SS II wheels with only minor rubbing on the front, and then only when you hit a bump with the front wheels turned hard (like entering a driveway).
Old Sep 15, 2013 | 03:44 PM
NHolds's Avatar
I have 255/60/15 on the front, and 275/60/15 on the rear... .and it's lowered. No rubbing.
Old Sep 15, 2013 | 04:57 PM
ziff396's Avatar
Same size tires here. Stock height no rubbing. When I had 1" lowering springs in the front it would rub with the wheels cranked on a small dip in say a driveway.
Old Sep 17, 2013 | 12:39 PM
Miles71's Avatar
I am running factory original suspension system on a 71-CS.
No spring modifications.
Front Tires: P245/60 R15 100S
Rear Tires: P275/60 R15 107S
BF Goodrich T/A.
Mounted on 1975 SS-III rims
No rubbing issues.
Old Sep 17, 2013 | 03:37 PM
Winger67's Avatar
Thanks for the replies. Think I'll go with 245/60R15 on all four corners.
Old Sep 28, 2013 | 04:23 PM
Scooby's Avatar
Good choice - my '71 Cutlass Supreme had SSIII 15x7 with BF Goodrich Radial T/As 245/60R-15s all around. Rubbed just a touch at full crank on the 1 3/8" non-stock front sway bar. Enjoy 'em - great tires great look great ride!
Old Sep 29, 2013 | 01:19 AM
BF Goodrich Radial TAs are the way to go on a Cutlass. White letter out of course.
Old Feb 17, 2014 | 05:19 PM
Bill72's Avatar
Does anyone have the 14x7 wheels? And if you do, what size tire are you using? Best I can figure is a 225/70r14. I want to put them on my 72 Cutlass Supreme.
Old Feb 17, 2014 | 05:31 PM
Rocketbrian's Avatar
You are right, they look the best on those size wheels. That's the equivalent of what GM put on the cars when new. (G70-14)
Old Feb 17, 2014 | 05:39 PM
11971four4two's Avatar
MOTORHEAD
I have the BF225/70/14 on some 14x7 SSI wheels - all 4 tires same size
On my 15x7 SSIII wheels i have mickey thompson 255/60/15
again all 4 tires the same size
Last edited by 11971four4two; Feb 18, 2014 at 03:33 PM. Reason: the white letter look is over go black wall
Old Feb 18, 2014 | 11:22 AM
Chumley's Avatar
Ditto. I have BFG225/70-14's on SSII"s with white letters on outside. My car looks exactly like Motorheads except for the rims and door guard trim on the sides. You probably don't want anything smaller, as it will not look right, and will throw off your speedometer a bit.(been there, done that)
Chumley
Old Feb 18, 2014 | 02:22 PM
Same as what I'm running on all 4 corners - SSIII's. The minor difference in tire size does throw out the speedo a bit though. I went blackwall out though. They're Kelly Chargers. Maybe next time I'll go BFG and put the white letters out. For now I like this look because it's all in sync with the black/silver theme.
Old Feb 18, 2014 | 03:25 PM
olds3442's Avatar
I like the Mickey Thompson sportsman st, something different, at shows I see bfg on seems like 75 percent of cars.not saying I don't like bfg those are nice to
Old Feb 18, 2014 | 03:31 PM
Nilsson's Avatar
I am doing MT's this time around myself. I think these will look sick on the poverty wheels with dog dish caps.
Old Feb 24, 2014 | 09:50 PM
johnnyjaws's Avatar
I was watching performance tv last night not shore of the company but they make replacement tires of the exzact tire ur car came with ill get the company name but they were big bucks like 325 a tire and it wasn't cooker tire
Old Feb 27, 2014 | 06:14 PM
Bill72's Avatar
I ordered some BF Goodrich tires this week and have been working on cleaning up the wheels. Using a paint stripper and then a sand blaster to get any rust off of them. Next step will be primer and paint. Anyone have advice or tips on this process?
Old Mar 7, 2014 | 07:31 AM
W31driver's Avatar
I have 225/70-14s on my 1970 Cutlass with poverty caps.
Old Mar 7, 2014 | 07:50 AM
Looks both correct and awesome, great choice.
Old Apr 8, 2014 | 07:20 AM
GoodOldsGuyDougie's Avatar
I'm running old style Bias ply on both of My 69 olds. Check them out in my aviator. Nothing looks as good on Crager SS Wheels. Picked them up from Summit cheaper than going to cooker even though they came from cooker. The drive just fine.
Old Apr 9, 2014 | 04:22 PM
BlueCalais79's Avatar
I've got Cooper Cobra's on my 72 Cutlass S. These are a nice white letter alternative to the BF Goodrich tires. I liked them so much I put a set on our 69 Camaro as well
Old Apr 14, 2014 | 05:34 PM
Bill72's Avatar
got a little more done on my wheels. got them all stripped down and repainted. The tires came in but i'm working out of town and can't mount them. here are a few pics of the progress i made the other week. Can't wait to get them mounted and put on the car.
Old Apr 14, 2014 | 05:56 PM
RetroRanger's Avatar
72 Olds CS
thsoe look real nice bill they will look even better onthe car !!!
jnaarnold
Sep 12, 2017 08:09 PM
navvet
Feb 3, 2014 02:44 PM
oldsguybry
Wheels and Tires
19
Feb 16, 2013 09:14 PM
rhaberm
Wheels and Tires
Aug 31, 2012 05:34 PM
Devon76
Apr 15, 2007 06:45 PM
