Tires for a '72 Cutlass
I think the BF Goodrich Eagle STs on the car are from '82. Probably time for new tires. BF Goodrich Radial T/A the way to go or is there another recommendation with white lettering? Any rubbing with 245/60R15?
Radial T/A's always look good and would be my first choice. I have 215/70 in the front, and 245/60 in the rear with no issues. Not sure about bigger tires on the front, maybe someone else will chime in.
Cooper also makes a nice white letter tire.
In any case, I've run 255/60-15 BFGs on all four corners of my 69 H/O on the stock SS II wheels with only minor rubbing on the front, and then only when you hit a bump with the front wheels turned hard (like entering a driveway).
I have 255/60/15 on the front, and 275/60/15 on the rear... .and it's lowered. No rubbing.
I am running factory original suspension system on a 71-CS.
No spring modifications.
Front Tires: P245/60 R15 100S
Rear Tires: P275/60 R15 107S
BF Goodrich T/A.
Mounted on 1975 SS-III rims
No rubbing issues.
BF Goodrich T/A.
No rubbing issues.
Good choice - my '71 Cutlass Supreme had SSIII 15x7 with BF Goodrich Radial T/As 245/60R-15s all around. Rubbed just a touch at full crank on the 1 3/8" non-stock front sway bar. Enjoy 'em - great tires great look great ride!
You are right, they look the best on those size wheels. That's the equivalent of what GM put on the cars when new. (G70-14)
I have the BF225/70/14 on some 14x7 SSI wheels - all 4 tires same size
On my 15x7 SSIII wheels i have mickey thompson 255/60/15
again all 4 tires the same size
Last edited by 11971four4two; Feb 18, 2014 at 03:33 PM. Reason: the white letter look is over go black wall
Ditto. I have BFG225/70-14's on SSII"s with white letters on outside. My car looks exactly like Motorheads except for the rims and door guard trim on the sides. You probably don't want anything smaller, as it will not look right, and will throw off your speedometer a bit.(been there, done that)
Chumley
Chumley
Same as what I'm running on all 4 corners - SSIII's. The minor difference in tire size does throw out the speedo a bit though. I went blackwall out though. They're Kelly Chargers. Maybe next time I'll go BFG and put the white letters out. For now I like this look because it's all in sync with the black/silver theme.
I was watching performance tv last night not shore of the company but they make replacement tires of the exzact tire ur car came with ill get the company name but they were big bucks like 325 a tire and it wasn't cooker tire
I ordered some BF Goodrich tires this week and have been working on cleaning up the wheels. Using a paint stripper and then a sand blaster to get any rust off of them. Next step will be primer and paint. Anyone have advice or tips on this process?
I'm running old style Bias ply on both of My 69 olds. Check them out in my aviator. Nothing looks as good on Crager SS Wheels. Picked them up from Summit cheaper than going to cooker even though they came from cooker. The drive just fine.
got a little more done on my wheels. got them all stripped down and repainted. The tires came in but i'm working out of town and can't mount them. here are a few pics of the progress i made the other week. Can't wait to get them mounted and put on the car.
oldsguybry
Wheels and Tires
19
Feb 16, 2013 09:14 PM
