tc help in 77 cutlass
Old Apr 25, 2011 | 06:04 PM
rayfrausto's Avatar
I have a 77 cutlass supreme with a 350 engine. So the car makes a little noise like sounds like a wobble(seems to be coming from flyweel/tc area). The engine dosent shake to bad but it dose slightly when you pop the hood u can see the motor shake bits its not really bad. So we looked at the flyweel to see if it was bent or rubbing on something everything good. Notice that on the torque converter there are small weights and we notice one to be loose it is like half way on half way off. So this can be the problem??? If si how to fix
Old Apr 25, 2011 | 07:32 PM
Rickman48's Avatar
Bent it back and tack weld it - good for another 25 years!
Old Apr 25, 2011 | 08:30 PM
rayfrausto's Avatar
Would I have to do any balancing or anything if it threw it off balance
nolabigdawg
Nov 16, 2014 06:45 PM
MJAKS462
Apr 15, 2010 02:34 PM
silverriff
Mar 24, 2010 06:36 PM
martine
Jan 22, 2009 01:13 PM
ToronadoGuyDenver
Brakes/Hydraulic Systems
Mar 18, 2007 02:52 AM
