Alternator Wiring Help
Old Feb 28, 2011 | 04:17 PM
plee3 64Olds's Avatar
Ok, this is my issue:
I purchased a 64 Cutlass with a 76 355 Cutlass engine in it. the generator light is illuminated on my dash and the alternator is not charging the battery. The alternator has 3 wires running from it. there are 2 14 gage wires running to the fire wall. there is an 8 gauge wire running to the inner fender well. Im thinking the 2 wires running to the firewall is not connected to the correct wires. I need some advice on how to make sure the alternator is wired up correctly. What wires should be hooked up to what??? remember, I have a 64. The engine is a 76.
Old Feb 28, 2011 | 04:39 PM
The engine is irrelevant. What alternator do you have? External regulator? Internal regulator? A photo would help us give you useful info.
Old Feb 28, 2011 | 05:08 PM
Ok. Im a newbe! LOL! How do I post pics on here???
Old Feb 28, 2011 | 06:23 PM
Let me upload all pics. I will have them shortly.
Old Feb 28, 2011 | 07:37 PM
Once you have typed in your post, scroll down before hitting Submit and you'll see a box for Additional Options, which includes Attach File. Note that there's a max file size limit, so you may need to resize the photos.
Old Feb 28, 2011 | 07:47 PM
Ok, here we go. I know I got a mess of wires there. I have to go behind some one else to higure out what's going on! I hate troubleshooting like that! LOL
Old Feb 28, 2011 | 07:51 PM
there is a junction point on the inner fenderwell drivers side. I see that the 8 gauge power wire goes there. Also, I was told that the box on the firewall that says Delco Remy is the voltage regulator. Could that be the culprit??
Old Mar 1, 2011 | 07:40 AM
OK, the alternator is an internally regulated 10SI or 12SI. The voltage regulator on the firewall needs to be bypassed if it isn't already. I can't tell from the photos if the alternator wires actually connect to the HEI terminal or not. In any case, here's how your car SHOULD have been converted to use that alternator:
In the diagram above, the red wire from the old voltage regulator terminal 3 runs to the junction block on the horn relay. The brown wire from the old regulator terminal 4 goes to the GEN light on the dash. I would also lose the crappy spade connectors on the alternator and get a proper connector and pigtail from NAPA or other auto parts store.
Old Mar 1, 2011 | 08:30 AM
Tony72Cutlass'S''s Avatar
Hey All,
I have a similar Alternator i believe on my '72 Cutlass with a 350.
My question is, does it matter if two connectors that fit onto the alternator (labeled 1 and 2 above in Joe's diagram) reversed? The previous owner had a similar setup (spade connectors) and i was looking to switch to a proper connector as shown above. Does it matter if the two terminals are reversed?
Thanks a bunch!
Cheers,
Tony
- 1972 Cutlass 'S' in Bamboo Yellow
Old Mar 1, 2011 | 09:07 AM
Very much so. That's why the stock connector only attaches one way.
Old Mar 1, 2011 | 09:26 AM
Okay great, thanks!
Would a similar wiring diagram as the one you posted need to be followed? The alternator I have is the same part number as from a 1983 Firebird (DELCO 10SI; 63 AMP)
Thanks again,
Tony
Old Mar 1, 2011 | 09:57 AM
Okay great, thanks!
Thanks again,
Tony
Yup. That diagram applies to any GM car originally equipped with an externally regulated alternator that is being converted to an 10SI or 12SI.
Old Mar 1, 2011 | 11:05 AM
Oh great! Thanks, i'll print that one out for my records.
Cheers,
Tony
Old Mar 1, 2011 | 12:07 PM
excellent diagram! I understand it! Ok, Like you stated, it does make a difference if the 2 wires are switched. as im looking at the diagram, would that be the front of the alternator or the rear?? oh, 1 more thing, whare is the horn relay located??
Old Mar 1, 2011 | 12:16 PM
The diagram is from the rear, but the casting is marked with #1 and #2 anyway. This is why you want to get the correct plug.
It's the box on the driver's side inner fender with the threaded post and the battery cable going to it. Just connect the red wires to that threaded post. I did exactly this conversion on my 62 F-85 wagon.
Old Mar 1, 2011 | 02:05 PM
Ok, you stated that "the red wire from the old voltage regulator terminal 3 runs to the junction block on the horn relay. The brown wire from the old regulator terminal 4 goes to the GEN light on the dash." but the diagram is showing something different. It shows the red wire connecting to the white wire and the brown wire connecting to the blue wire. then the blue and white wires are connecting to the alternator.
Old Mar 1, 2011 | 02:09 PM
I was talking about the OTHER ends of those wires, which are not shown in that drawing. Your car has obviously been monkeyed with by someone so you need to verify that those wires actually go where they are supposed to if you use them. Otherwise you may introduce new problems without knowing why.
Old Mar 1, 2011 | 09:35 PM
You know what, you are correct. I just ordered the wiring diagram for the 64. At least that will give me a solid base on these electrical issues. I will keep you posted! I Thank for your assistance! You really helped me out!
Old Mar 2, 2011 | 11:42 AM
I just found that pigtail at my everday auto parts store (Canadian Tire) for 2.99, heck of a deal for finally getting my alternator to charge my battery right, heh.
Cheers,
Tony
Old Mar 3, 2011 | 06:07 AM
I came to the conclusion that the alternator is bad. I did the rewire and the alternator still wasnt charging the battery! I removed the alternator and had it checked. it failed! I purchased a new one< installed it and it worked like a charm! I just have wiring issues inside the car. Thanks for all the assistance everybody!!
Old Mar 6, 2011 | 09:12 AM
Now that I have a charge going to the battery, I would like to know how to bypass the external voltage regulator in the firewall. Do I cut the 4 wires and tie them together?? Please leave feedback.
Old Mar 7, 2011 | 08:40 AM
You already have bypassed it. Simply remove the regulator and tie the remaining pigtail up neatly. Don't go cutting anything.
Old Mar 7, 2011 | 10:20 AM
One more question, I still have a GEN light on the dash when my car is running. I have the new alternator installed. I have a 4 Gauge wire from the alternator to the horn relay. I have also have the red wire (I picked up the pig tail like you suggested) connected to the 4 Gauge wire. (same as running it to the horn relay) Now where does the white wire go?? I remember you stated that the brown wire from the external regulator was responsible for the GEN light. Do I hook the white wire from my alternator to the brown wire from the external regulator?? Im sorry if I am asking alot! LOL!! Im almost finished with the charging situation.
Old Mar 7, 2011 | 10:47 AM
Yes.
Old Mar 11, 2011 | 06:50 AM
I have started the painful rewiring process! LOL!! Its a mess! (well, not really) I still have a gen light on the dash when the car is runningI have studied the diagram and this is my understanding:
1. On the voltage regulator, the brown wire has a dotted arrow leading to the blue wire. Then the blue wire runs to #1 terminal on the alternator.
2. On the voltage regulator, the red wire has a dotted arrow leading to the white wire. Then the white wire runs to #2 terminal on the alternator.
3. The big 4ga wire from the alternator runs to the horn relay.
What else am I missing here?? If someone has some real pics to post, it would really help. Thank you gentlemen for all of your assistance!
Old Mar 11, 2011 | 10:57 AM
Let's start with basic troubleshooting.
1. With the engine off, key in the RUN position, disconnect the plug from the back of the alternator. The GEN light should be off. If not, this wire is shorted to ground somewhere.
2. Engine still off and key in RUN, check the red wire in the connector for power using a test light or a voltage meter. There should be battery voltage (about 12V). If not, there is a break or bad splice somewhere in this wire.
3. Engine still off and key in RUN, connect a jumper wire from the white wire in the connector to the battery +terminal. The GEN light should go off. If not, there is a break or bad splice between the connector and the GEN light.
Run these tests and report back.
Old Mar 12, 2011 | 05:46 AM
Thanks for the steps Joe! That helped! I physically removed both wire harness from the firewall. WOW! WHAT A MESS! The red wire was melted to oher wires So somthing was shorted! I removed both harnesses and cleaned them up pretty good. I wired everything back and to my suprise, the gen light goes out when the car is started! Great! Im going in the right direction! I unplugged all of the spark plug wires and I cant ge the car started again. I will keep you posted on further events!
Old Mar 12, 2011 | 12:17 PM
Day 2 of troubleshooting. I loose 12V going to the HEI Distributor. Since The 2 big red wires were melted< i decided to go ahead and order ALL wire harnesses (dash, engine starter, front lights, rear lights) all new wire is needed. I will udate you on my progress. Your assistance really helped me out. I have the wiring schematic so I should be ok. My engine and trans is fine. Just alot of wiring issues.
Old Mar 12, 2011 | 01:35 PM
compedgemarine's Avatar
if you order new harnesses in stock form they will probably have a resistor wire going to the coil. this would need to be replaced with a regular wire. if you talk to the people you are getting the harness from and tell them you have an HEI most offer a harness that is already converted for electronic ignition
Old Apr 26, 2011 | 06:50 AM
Hey Joe,
Just wanted to say thanks for the diagram you supplied earlier in this post, i hooked up a 10SI alternator from '83 in my 72 Cutlass and it's charging without fail at 14+ Volts. Pretty awesome!
Cheers,
Tony
Old Apr 26, 2011 | 09:05 AM
  #31
Hey Joe,
Cheers,
Tony
Glad it worked for you.
442mark
Sep 30, 2017 01:06 PM
Takid455
Oct 29, 2014 07:00 PM
Mark71
Apr 19, 2012 07:36 PM
neller840
Aug 5, 2011 06:15 AM
69sAndrew
Sep 15, 2008 07:29 AM
