Shoulder Belts
Old Jun 16, 2011 | 03:44 PM
425HP409's Avatar
Restorer
Smile Shoulder Belts
I have a pair of factory shoulder belts to install in my 67 442 and am wondering if anyone knows exactly where the factory anchor holes are behind the headliner. I do not want to remove the headliner as it is original and perfect. I can't find a measurement to go by, does anyone have shoulder belts in their 67 or know what the measurement is.
Old Jun 16, 2011 | 03:57 PM
jaunty75's Avatar
Have you tried feeling around for them? The headliner can't be too terribly thick, I would think you could feel the hole for the bolt.
Old Jun 19, 2011 | 08:09 PM
Chumley's Avatar
I had this to deal with after I installed a new headliner on my '72.( although I had the advantage of seeing where the holes were before the install) If a '67 is anything like later years, you can feel through the headliner using your fingertips for a raised boss with a dimple-like depression. When you find the two close together, measure the distance between them and then verify with your mounting bracket. Nothing worse than punchimg an unwanted hole in a nice headliner. Chumley
Old Jun 19, 2011 | 08:14 PM
oldspackrat's Avatar
I know in the '70-'72 service manual, or assembly manual?? it shows an illustration of where they are. I would be the '67 manual might also?
Good luck.
Old Jun 19, 2011 | 08:31 PM
425HP409's Avatar
Restorer
shouldler belt
Due to a photo that "Oldsmobility" posted of a roof without headliner I was able to find my mounting holes for the shoulder belts. There is a raised pad right in front of the coat hook with three holes in it. The front and rear holes are for the seat belts. I pushed hard with my finger and found the holes, I then pushed a scribe through the hole and then pushed the bolt through the hole and mounted the shoulder belts in the threaded holes. I feel so much safer now when driving. The 68's built before Jan 1, 68 without belts will also have the same threaded mounting pads
bigfun64mo
Oct 30, 2021 09:15 PM
jcmoretti
Jul 11, 2018 03:07 PM
tmbrennan
Aug 31, 2011 03:34 PM
woodie582
Oct 2, 2009 01:56 PM
stevengerard
Sep 26, 2009 08:59 AM
