in search of build sheet, found this!
Old Jun 17, 2018 | 12:46 PM
razman427's Avatar
1969 Cutlass S with 48k original miles..unrestored and untouched. i decided to try to find the build sheet/broadcast sheet. i pulled the rear seat out last night and found some documentation. i'm assuming this is a portion of the build sheet that was given to the upholstery guy, (basically all it contains is body color, interior number and body number) it was actually attached to the rear seat framework with hog ties. i went ahead and pulled the seat back out also, and didn't find anything else. where would the most likely place to find the build sheet on a Lansing october 68 built car?? thanks! Rick
Old Jun 17, 2018 | 01:03 PM
My442's Avatar
Soft Trim broadcast card......that gave the line inspection the specs on the interior.
Old Jun 17, 2018 | 01:49 PM
Hairy Olds's Avatar
Shoveling Snow
Well more correct it's a Fisher body broadcast card. The body #s should match the trim tag under the hood.
Old Jun 17, 2018 | 02:01 PM
razman427's Avatar
yep, numbers on this card match the trim tag. does any body have a best guess for where the chassis and body broadcast sheets would be?
Old Jun 17, 2018 | 03:47 PM
rcorrigan5's Avatar
Randy C.
You will be extremely lucky to find a build sheet on a Lansing car. The assembly people were pretty thorough about removing things that weren't supposed to be there and the build sheet was one of them.
Places to look, just in case: Above the gas tank (between the tank and the tank pad), behind a bucket seat back, behind a rear seat side panel, behind a door panel, stuffed up in the dash.
Randy C.
Old Jun 20, 2018 | 03:57 AM
rustyroger's Avatar
'87 Delta 88 Royale
I wouldn't tear the car apart looking for it. If it was supposed to be in the car it would be in the document folder given to whoever bought it new.
Some factories were sloppy about removing them, apparently Lansing wasn't.
The sheet you found was supposed to be there, or it wouldn't be hog tied to the seat.
But you might get lucky, people win lotto jackpots after all.
Roger.
Old Jun 20, 2018 | 04:54 PM
razman427's Avatar
Roger.
i agree....not worth tearing the car apart to locate the build sheet.....i did pull the rear seat out (wanted to look, and it made it easier to give interior a good cleaning) and i do intend to drop the gas tank, to clean it out thoroughly, and replace the rubber vent lines and feed line. here's a couple of pics of the interior with seat out...car is amazingly solid.
Old Jun 20, 2018 | 05:13 PM
Not only solid, but amazingly clean. Mine was comparable to what you'd see behind the refrigerator in an old house.
Old Jun 20, 2018 | 07:01 PM
Yellowstatue's Avatar
Expired ice cubes...
Old Jun 20, 2018 | 10:26 PM
cjsdad's Avatar
You would be totally grossed out knowing some of the things I found under the back seat of cars when I was installing stereos. I once took the rear seat out of a 73 Nova and found actual plants growing. Your car is practically sterile!
Old Jun 22, 2018 | 05:17 AM
rustyroger's Avatar
'87 Delta 88 Royale
Not as startled as a friend who imported a Mustang many years ago. Bear in mind it cleared customs and inspection in the USA before shipping, and in the UK when it arrived. He found two sticks of dynamite under the back seat.
Roger.
Old Jun 22, 2018 | 07:31 AM
jaunty75's Avatar
You won't find one. As Rusty Roger notes, the Lansing plant was meticulous about not leaving them in the car.
Old Jun 22, 2018 | 09:54 AM
My442's Avatar
It depends.....IF the plant had a Fisher Body process.
When I worked at Framingham in 1972, there was no separate Fisher Body plant providing the bodies. They were all built on the same assembly line.
GreatSX
Nov 20, 2020 09:31 AM
442craig
Dec 20, 2017 04:42 PM
sammy
Nov 5, 2013 09:17 PM
98 man
Jan 15, 2012 02:00 PM
rrielley
Jan 29, 2008 03:13 PM
