rearview mirror map light
Old May 24th, 2010, 08:39 AM
bigfun64mo's Avatar
The maplight on the rearview mirror does not work. I have not tried to trouble shoot it. It does not bother me that is doesn't work, I am just wondering has anyone heard of replacing the LED light? It could be a bad wire too.
bigfun64mo is offline
Old May 24th, 2010, 08:58 AM
Oldsdruid
rocketraider's Avatar
What year car?
Depending on year, either the lights or ignition has to be on for the mirror map light to work.
rocketraider is online now
Old May 24th, 2010, 06:09 PM
Registered
Bluevista's Avatar
In my '71 it works with the ignition and lights off.
It not an LED, just a basic tube type bulb, It's acceseed by squeezing the lens/switch on each side and pulling it down, it should show the type bulb you need and how to get to it in the owner's manual.
Could be a bad wire, loose connection under the dash, dirty contact, bad bulb, bad ground, not much more to the things.
Those mirrors are all of a sudden worth big bucks, for the man who has everything (else) I guess.
Bluevista is offline
Old May 24th, 2010, 06:21 PM
1972 Cutlass 455
silverriff's Avatar
I have a mirror that's not working either. I spent over an hour messing around with it to try to get it to work. What I finally did was rig up a 9 volt to the switch, and mirror casing. What I figured out is that the copper prong opposite the one that contacts the bullet connector( hot wire) doesn't seem to be long enough to contact the case to ground it. I had to twist the prong and wedge it in there and the light lite up, but there is no way I could, or would, keep it like that. The switch/bulb housing doesn't look like it was modified in any way. Does anyone have a picture or diagram of how the switch is supposed to look?
silverriff is offline
Old May 25th, 2010, 08:52 AM
bigfun64mo's Avatar
Thanks guys,
BlueVista, I will take a close look at the bulb. It sure looks like and LED type bulb to me. I was thinking that it was a pretty hi-tech item for the time.
Old May 25th, 2010, 09:11 AM
Oldsdruid
Bigfun, are you seeing the little tit on the lens that protrudes below the mirror? That's just there as a visual indicator the map light is on.
Old May 25th, 2010, 12:33 PM
Lady72nRob71's Avatar
Yep - the bulb itself is under the clear lens. LEDs were in their infancy back then...
Lady72nRob71 is offline
Bunser
August 31st, 2019 04:35 PM
ros6872
March 10th, 2015 09:16 AM
pfergy600
March 12th, 2014 12:40 PM
bobb
November 18th, 2010 09:26 AM
jeffreyalman
May 11th, 2010 03:36 AM
Quick Reply: rearview mirror map light
