rearview mirror map light
Old May 24, 2010 | 08:39 AM
bigfun64mo's Avatar
The maplight on the rearview mirror does not work. I have not tried to trouble shoot it. It does not bother me that is doesn't work, I am just wondering has anyone heard of replacing the LED light? It could be a bad wire too.
Old May 24, 2010 | 08:58 AM
rocketraider's Avatar
Oldsdruid
What year car?
Depending on year, either the lights or ignition has to be on for the mirror map light to work.
Old May 24, 2010 | 06:09 PM
Bluevista's Avatar
Registered
In my '71 it works with the ignition and lights off.
It not an LED, just a basic tube type bulb, It's acceseed by squeezing the lens/switch on each side and pulling it down, it should show the type bulb you need and how to get to it in the owner's manual.
Could be a bad wire, loose connection under the dash, dirty contact, bad bulb, bad ground, not much more to the things.
Those mirrors are all of a sudden worth big bucks, for the man who has everything (else) I guess.
Old May 24, 2010 | 06:21 PM
silverriff's Avatar
1972 Cutlass 455
I have a mirror that's not working either. I spent over an hour messing around with it to try to get it to work. What I finally did was rig up a 9 volt to the switch, and mirror casing. What I figured out is that the copper prong opposite the one that contacts the bullet connector( hot wire) doesn't seem to be long enough to contact the case to ground it. I had to twist the prong and wedge it in there and the light lite up, but there is no way I could, or would, keep it like that. The switch/bulb housing doesn't look like it was modified in any way. Does anyone have a picture or diagram of how the switch is supposed to look?
Old May 25, 2010 | 08:52 AM
bigfun64mo's Avatar
Thanks guys,
BlueVista, I will take a close look at the bulb. It sure looks like and LED type bulb to me. I was thinking that it was a pretty hi-tech item for the time.
Old May 25, 2010 | 09:11 AM
Oldsdruid
Bigfun, are you seeing the little tit on the lens that protrudes below the mirror? That's just there as a visual indicator the map light is on.
Old May 25, 2010 | 12:33 PM
Lady72nRob71's Avatar
Yep - the bulb itself is under the clear lens. LEDs were in their infancy back then...
Bunser
Aug 31, 2019 04:35 PM
ros6872
Mar 10, 2015 09:16 AM
pfergy600
Mar 12, 2014 12:40 PM
bobb
Nov 18, 2010 09:26 AM
jeffreyalman
May 11, 2010 03:36 AM
