Rear window..
Old Feb 2, 2013 | 06:01 PM
snookys71olds's Avatar
Rear window..
I have a question maybe someone can help me out with...I have a 71 Cutlass S..took the rear glass out to clean the rust out..and replace the seal...Now does this use a gasket to re install it.. or does it just use the roll of windshield glass tape that comes in a roll...any help would be appreciated..
Old Feb 3, 2013 | 07:35 AM
442Harv's Avatar
No gasket used,I use the rope, but buy it from a company that sells a lot of it so it isin't old.
Old Feb 3, 2013 | 07:38 AM
69442C's Avatar
No gasket, just the butyl rubber ribbon tape that comes in a roll. Be sure to use 3/8" an not 5/16". If you were to have a glass shop install the glass, they would use a urethane caulk adhesive which is better than the butyl tape.
Brian
Old Feb 3, 2013 | 08:00 AM
ok. got it.. thanks for the replys..
wyteon
Vista Cruiser & Wagons
Nov 30, 2018 11:33 AM
f-85
Jan 16, 2012 06:10 AM
jugdish
Aug 18, 2011 09:57 AM
leepear
Apr 22, 2011 02:22 PM
72RocketPower
Nov 22, 2004 02:02 PM
