Rear coil springs
Rear coil springs
I have done the searches on the forums, read post of others and that is how I came to these 3 rear coil springs but I still have questions about them, so I figured I will post and ask. What I want to do is raise my rear about a 1 inch maybe 2. It is a 1969 cutlass with a 1970 442 rear end.
I was looking at the Moog CC507 which are for the vista cruiser. Some say it will raise it an inch but the question I have is what shocks do I get? Do I go with shocks for my car or do I have to get the shocks for the vista cruiser? I am asking because I am worried about the mounting brackets not lining up.
I also found the moog 5409 which are for a 442 and I have read that some say this also raised the rear about an inch. What I don’t understand is why would the 442 ones raise it an inch but the stock cutlass S won’t what is different about them? What shocks do I use 442 or cutlass s?
Last I also call Eaton’s and got a price for 1 inch lift springs from them and I was wondering if it would be easier and more of guarantee that I get the inch I am looking for. Even thou they’re way more money than the others.
I live in New York City where the roads have nothing but pot hole everywhere so I am also looking for the best shocks to get, any ideas?
Thank You
Thank You
Here's a sample of front spring specs from the Moog catalog; rears would be similar:
> 5390 small block - no AC
> wire diameter = 0.650"
> load height = 11.000"
> load = 1952 pounds
> rate per inch = 336 pounds
> free height = 16.808"
> 5382 big block - no AC, small block - AC
> wire diameter = 0.660"
> load = 2066 pounds
> rate per inch = 360 pounds
> free height = 16.724"
> 5400 big block - AC
> load = 2167 pounds
> free height = 17.004"
> 5536 442 small block - AC - heavy duty, 442 big block - no AC - heavy duty
> wire diameter = 0.690"
> load = 1984 pounds
> rate per inch = 488 pounds
> free height = 15.063"
> 5450 small block - AC - heavy duty, big block - no AC - heavy duty, -442 big block - AC - heavy duty
> load height = 12.000"
> load = 1642 pounds
> rate per inch = 454 pounds
> free height = 15.616"
Thanks for the info guys. I think I am going to try these out I got them for a good deal $60 for the pair Monroe Sensa-Trac Load Adjusting Shock Absorber and we will see. I will just keep trying different once in till I get it the way I want. :P
RetroRanger
Feb 25, 2014 05:04 PM
