Radiator top plate question/fan/clutch
Old Jun 28, 2022 | 03:11 PM
AK71CutlassS's Avatar
Looking for info on a top plate for a 1971 Olds cutlass S. the black one is what came originally on car. 4 blade fan and no shroud
i want to put a clutch fan on and shroud. The other red one has holes. Is that stock to have the holes in that location..?
It is sorta like they were drilled I can’t really tell. I am putting a 455 in
if not what is the correct top plate for fan shroud
what is the correct fan and what is the correct clutch for 1971
Old Jun 28, 2022 | 03:21 PM
v8al's Avatar
Registered Olds Owner
This is the other top plate for a 71. Note this is for a 4 core (thicker) radiator
4 Core Radiator Top Plate, 1969-72 Cutlass/442
Old Jun 28, 2022 | 03:31 PM
Yeah not looking for a 4 core top plate. Using a 3 core rad.
Old Jun 28, 2022 | 03:45 PM
v8al's Avatar
The 3 core top plate looks almost exactly like the 4 core top plate except at the ends where rubber saddles are installed.
Old Jun 28, 2022 | 03:46 PM
4speed455's Avatar
Both top plates you have pictured are for non shroud applications. I have this three core top plate for use with a shroud available below.
https://classicoldsmobile.com/forums...coated-145542/
Old Jun 28, 2022 | 03:54 PM
v8al's Avatar
Personally I wouldn't spend money on a 3 core top plate. I'd upgrade to the 4 core plate and use the 3 core rubber isolators. Then a future upgrade to a 4 core is less of an issue. You still would need to install the lower 4 core saddles and buy the 4 core rubber isolators.
Old Jun 28, 2022 | 04:56 PM
K sounds like my two options are original 3 core top plate or a
4 core plate with 3 core insulators
how about the correct fan and clutch PN’s?
chopolds
Apr 30, 2022 04:42 AM
72GoldOlds350
Apr 25, 2020 12:59 AM
matt69olds
Jul 10, 2019 06:43 PM
rothlane'68
Jun 27, 2017 09:46 AM
midrange
Apr 22, 2014 02:02 PM
