Looking for info on a top plate for a 1971 Olds cutlass S. the black one is what came originally on car. 4 blade fan and no shroud
i want to put a clutch fan on and shroud. The other red one has holes. Is that stock to have the holes in that location..?
It is sorta like they were drilled I can’t really tell. I am putting a 455 in
if not what is the correct top plate for fan shroud
what is the correct fan and what is the correct clutch for 1971
Personally I wouldn't spend money on a 3 core top plate. I'd upgrade to the 4 core plate and use the 3 core rubber isolators. Then a future upgrade to a 4 core is less of an issue. You still would need to install the lower 4 core saddles and buy the 4 core rubber isolators.
Reason: Added additional info
