axle flange runout question
Old Jul 12, 2022 | 07:49 AM
Minnesotajeff's Avatar
My question is whether the stock axle flanges should be perfectly round along the outer edges or not. If I put the rear of the car on stands and run it in gear without the wheels on, it appears that the center wheel-locating part of the axle (yellow arrow) is steady and true, but the outer edge of the flange (blue arrow) is not true. Please see the attached image to help understand what I'm describing. The outer flange edge (blue) doesn't spin in a perfect circle, it wobbles. But the center (yellow) "appears" to spin in a perfect steady circle. I say appears because it is difficult to be certain, but I can't visually see any wobble or movement of it.
They are stock axles on a 65k mile all original 1972 Cutlass. The attached image is just something i grabbed to help explain my question.
Old Jul 12, 2022 | 08:13 AM
The outer edge is not a controlled surface. The pilot (yellow arrow) is what centers the brake drum and wheel. That flange OD can be square and it wouldn't matter.
Owen Miller
Oct 13, 2021 04:35 PM
Steve 76
Drivetrain/Differentials
Aug 27, 2018 09:16 PM
walter thornberg
Aug 19, 2013 05:57 AM
oldspower_68
Jan 1, 2013 09:48 AM
RetroRanger
Oct 19, 2012 07:09 AM
