oil guage help?
Old Feb 20, 2016 | 12:10 PM
falandys1002's Avatar
oil guage help?
I bought a 84 cutlass a couple weeks ago, it's got a big block 455 that I was told was out of a 68 delta in it. The last guy didn't hook any guages up but had them in the trunk, the temp and volt guage was easy but the kit doesn't come with a bushing for 1/8" to connect to the spot where the old sending unit went. is there somewhere else I could connect this thing to?
Old Feb 20, 2016 | 12:31 PM
There is only one oil pressure port on the motor - the 1/8" NPT tapped hole at the front. Do you have a mechanical or electrical gauge? The installation kits for mechanical gauges typically come with a 1/8 NPT fitting. Most electrical oil senders are either 1/8 NPT or 1/4 NPT. Any good hardware store or most well-stocked auto parts stores have drawers full of brass pipe adapters.
Normally you'd get an adapter like this, but this likely won't fit in the small space available.
In this case, you probably want a female-to-female adapter and a 1/8 NPT nipple to extend it.
Old Feb 20, 2016 | 12:52 PM
Thanks for the reply, the kit was openned but the bag with the adapters was still sealed, and no 1/8" =( ...I'm a pipe fitter by trade, too bad we don't use 1/8" .. I'll run to the hardware store and see what I can find
charlierogers
Mar 11, 2013 05:43 AM
Kid64
Jan 2, 2013 04:11 PM
Finn5033
May 15, 2012 10:57 AM
Finn5033
Apr 10, 2012 09:23 AM
