new project, 1972 Supreme coupe, before pics
Old Jun 1, 2010 | 07:44 AM
architect's Avatar
OK, pics as promised in the Newbies thread. This is what I'm starting with. The current goal is to have it in "reasonable" daily driver shape in a "reasonable" time frame (no, I am not going to be pinned down defining reasonable!), but I am not ruling out "mission creep."
Info: S/N 3J57K2M235354
BDY code: ST72 34257LAN496245
PNT code: TR 977 11 A
TRM code: 05D A65 B85
Old Jun 1, 2010 | 08:05 AM
lshlsh2's Avatar
71 cutlass convertible
Looks promising good luck.
As for a time frame. The day after I got mine I hung a sign in my garage.
This project is currently 3 years ahead of schedule
Larry
Old Jun 1, 2010 | 08:18 AM
slowolds's Avatar
Loose Radical
Looks like a good start....................
If you have it running and stopping reliable you have a 'reasonable' daily driver.
Once you say 'I think I'll clean up the grill, oh the I should paint the enigine compartment, I should get new carpet.........'
you start the domino cascade that keeps it in a garage and not on the road.
Good luck and don't get caught up in the cosmetic department.
These cars are more fun to drive than to look at in your garage.
Old Jun 1, 2010 | 09:03 AM
architect's Avatar
Here's my first stupid question...
In the engine photo, you can see that the left valve cover has a "D"-shaped plastic fitting (called a grommet?) with a big hole, too big for the PCV. Unseen,the right valve cover has a plastic fitting with a small hole, too small for the filter/hose that goes into the air cleaner housing, but about right for the PCV (says "valve" on it too). Is it possible that the valve covers are swapped? Can I swap just the fittings back? Is doing the latter a good idea?
Old Jun 1, 2010 | 12:17 PM
slowolds's Avatar
Loose Radical
Check out this add, it has some great close-ups of the comb you have I think.
http://cgi.ebay.com/ebaymotors/Oldsm...item3f000a67e9
Looks like a different grommet on the left for the pcv.
You can probably swap them without pulling the valve covers.
Old Jun 1, 2010 | 12:37 PM
67 Cutlass's Avatar
Nice car for a driver!
Old Jun 1, 2010 | 02:57 PM
architect's Avatar
Yeah, they swapped, but the PCV grommet was old and dried up enough to split almost in two when I pulled it out of the hole in the VC. Thanks anyway!
Old Jun 1, 2010 | 05:28 PM
extreme1's Avatar
Valve covers are correct, my PCV valve is on the passenger side and the inlet tube on the drivers side.
I don't use the stock air cleaner assembly to my inlet is just a filtered breather.
84oldsDelta88
Mar 3, 2012 06:14 PM
hunter
Sep 1, 2011 12:20 PM
scott_442
Jun 11, 2009 03:31 AM
dhoff
Jun 8, 2009 10:40 AM
Droopys Garage
Aug 1, 2008 06:01 PM
