A few pics of my 72 Supreme project
Old Jun 7, 2009 | 04:51 PM
dhoff's Avatar
You guys are always saying that you like pictures, so I thought I would post a few progress pics.
Old Jun 7, 2009 | 06:38 PM
citcapp's Avatar
Looks like your making good progress. Still some work to go. When do you think you'll have it on the road
Old Jun 8, 2009 | 04:02 AM
dhoff's Avatar
I'm will be driving it by this fall, completed probably never. I have most everything painted now except the engine and rear. I am going to just regasket the engine(350), it ran well, no noises or smoking, compression was good,etc. I am puting Hochkis arms and sway bar on the rear, and in the front new enegy suspension urethane bushings with the stock arms and a Hochkis 1 3/8 sway bar. Going for the stock look 14" SSII's and put disc on the front only. I would like to test drive it this fall and finish the little things next winter(lots of winter time in PA).
Old Jun 8, 2009 | 10:04 AM
#1CutlassSupreme's Avatar
Lookin good!!!!
If you're going to regasket the engine, you might consider a little valve job while you have it open...Oh and a porting the heads...and flat top pistons, new rings...oh and you can't forget new mains...and since you have it apart...might as well do some new roller rockers and a fresh cam.
Old Jun 8, 2009 | 10:40 AM
Look'in Good
Beautimus
When you finish would you mind comig down and finishing up mine.
gearheads78
Jan 15, 2013 02:00 PM
wilfredacree
Feb 18, 2009 06:30 PM
csouth
Dec 4, 2008 01:12 PM
Droopys Garage
Aug 1, 2008 06:01 PM
TheBiggness
Mar 8, 2007 05:27 AM
