Need Info on 68 Cutlass Convertible
Old Aug 14, 2009 | 04:40 AM
sklbndt's Avatar
I am considering a 68 Cutlass convertible and am wondering what are the major concern/problem areas of this model. Car is partially restored so, in other words, if I go look at it what are the areas I should concentrate on? Drive train is not original so I'm not overlly concerned with that. Mostly need input having to do with chassis, body, and frame issues (ie., weak points, parts impossible to find, etc.). Any and all information is greatly appreciated!!
Old Aug 14, 2009 | 06:04 AM
There is alot of good info on our website. Stick around and you will pick up alot of good advice. I don't know much about A bodies; however, I've heard that reproduction fenders, hoods, bumpers etc. don't fit very well. You are better off finding a parts car if you need these parts.
Old Aug 14, 2009 | 06:53 AM
Oldsmaniac's Avatar
As with all converts make sure box frame is not rotted. Usually a problem on driver's side near front wheel and back. Also floor pans tend to go quicker as sometimes drips of water enter at side sealing strips. Other than that not much different than other a bodies.
Old Aug 14, 2009 | 09:13 AM
sklbndt's Avatar
When you say "box frame" you're referring to the frame itself correct?
Old Aug 14, 2009 | 09:34 AM
Oldsmaniac's Avatar
Yes the frame is boxed on converts which holds dirt water salt etc and causes rot.
Old Aug 14, 2009 | 09:53 PM
sklbndt's Avatar
Can anyone think of a legitimate reason why a 68 Cutlass convertible which should have a VIN of 336678 would have a VIN of 335578?
Old Aug 15, 2009 | 08:54 PM
69ho aurora's Avatar
A 335678 would be a legit 6-cyl convert VIN, not that I've ever seen one...
Old Aug 16, 2009 | 06:06 AM
68conv455's Avatar
Correct on the 6 cyl vin. I've seen one. It's in my garage.
According to my "Std. cat. of American cars" something like 400 were made.
Nothing to fear though. A 455 fits just fine.
Old Aug 16, 2009 | 08:05 AM
66400's Avatar
The quarter panel long upper moldings are hard to find if missing. Henry
Manuelte
Nov 5, 2014 06:58 AM
sx455raidercelticfan
Aug 1, 2010 08:03 PM
viper771
May 31, 2010 12:40 PM
WesB.
Apr 14, 2007 09:16 PM
Ando07
Feb 20, 2007 06:54 PM
