Need Info on 68 Cutlass Convertible
I am considering a 68 Cutlass convertible and am wondering what are the major concern/problem areas of this model. Car is partially restored so, in other words, if I go look at it what are the areas I should concentrate on? Drive train is not original so I'm not overlly concerned with that. Mostly need input having to do with chassis, body, and frame issues (ie., weak points, parts impossible to find, etc.). Any and all information is greatly appreciated!!
There is alot of good info on our website. Stick around and you will pick up alot of good advice. I don't know much about A bodies; however, I've heard that reproduction fenders, hoods, bumpers etc. don't fit very well. You are better off finding a parts car if you need these parts.
As with all converts make sure box frame is not rotted. Usually a problem on driver's side near front wheel and back. Also floor pans tend to go quicker as sometimes drips of water enter at side sealing strips. Other than that not much different than other a bodies.
Manuelte
Nov 5, 2014 06:58 AM
