Metal Dash Paint
Old Apr 13, 2010 | 09:29 AM
Olds luvr's Avatar
Grown Azz Kid
Metal Dash Paint
Looking for info on the metal part of the dash. Need to paint it and can not find what type of paint it was or the code. I do not believe it was the same as the pad and would guess it was flat but want to make sure I get it done right. Anyone know for sure of the code and what paint?
Old Apr 13, 2010 | 01:28 PM
The paint chip charts at auto paint stores list the interior paint codes, usually on the back of each sheet.
Old Apr 13, 2010 | 07:41 PM
hinz57's Avatar
Ditzler code (PPG Industries) for 1972 interior flat black was 9317 which I believe was used on the metal upper instrument panel and lower AC Valance panel. Semi gloss #9387 was used on Ash tray door, console door, steering column etc. That is what is listed on the back of the PPG paint code page.
Old May 21, 2010 | 07:15 PM
Kace's Avatar
I have 68 convertible and also painting metal dash. Does anyone know if my metal parts match the dash pad?
Old May 21, 2010 | 09:41 PM
Olds luvr's Avatar
Grown Azz Kid
Kace, The metal dash is a different type of paint. I just finished mine (black) and is a PPG laquer. PPG is the only one that does laquers (so I've been told) and has a flatener and a texture to it. Find an auto supply store that sells PPG and get your paint code to have them mix it. If you care to see mine the pictures are below
Old Feb 22, 2022 | 06:35 AM
Dcreamer71's Avatar
Looking for advice on what type of paint to redo my center console on my 68 Cutlass conv. And also the metal dash? I have a black interior car.
Thanks in advance
Dennis
Old Feb 22, 2022 | 09:29 AM
Thanks in advance
Dennis
The metal dash is painted just like the outside of the car. The formulas/color codes are in the Product Information Manual. The plastic console either needs plastic paint or an adhesion promoter prior to using other types of paint. Typically you'll want to use enamel on the plastic.
Old Feb 22, 2022 | 09:48 AM
RetroRanger's Avatar
72 Olds CS
SEM brand landeau black is a good choice for the console
Old Feb 22, 2022 | 10:07 AM
allyolds68's Avatar
I also used it on the metal dash. It's still good as new after about 15 years
Old Feb 22, 2022 | 10:24 PM
Thanks in advance
Dennis
If you have the paint code, any automotive paint supplier should be able to mix paint in the correct formula for both metal and plastic.
I can tell you from experience, the hardest part of painting the interior is cleaning it. People really like to layer on the detailer on the dash and console. I use Comet bathroom cleaner and a scotch bright pad to clean and scuff the surface, and then lots of wax/grease remover. When you think it’s clean enough, do it again. First time I painted the interior of my car I was rewarded with fisheyes in the paint.
hilbily
Body work
Sep 9, 2014 08:54 PM
Flye
Paint
Mar 27, 2012 07:47 AM
KZ442
Aug 12, 2010 08:14 PM
Kidcutty
Jan 18, 2010 04:04 PM
Keieljun
Apr 28, 2008 03:25 AM
