Master Cylinder question
Old Sep 6, 2012 | 03:17 AM
Steve69's Avatar
I have a 69 Cutlass with four wheel drums. My master cylinder is on it's way out and I was wondering if I could use one for a front disc/rear drum setup. The reason I ask is because I want to upgrade to front disc in the future because I cannot afford to right now. I don't want to have to get a new master just to have to get one AGAIN in a few months. What do you guys think?
Old Sep 6, 2012 | 03:44 AM
No way, José.
Old Sep 6, 2012 | 04:05 AM
Rickman48's Avatar
X2 - completely different, and for $50, why chance it?
Old Sep 6, 2012 | 01:07 PM
mpolds's Avatar
Master Cylinder Answer
It's your brakes -- it's your life... be ONLY perfect.......
Neither Master cylinder is pricey... if you want U S A made quality ---
call me --- Craig -- 516 - 485 - 1935.....New York.....
Old Sep 6, 2012 | 02:30 PM
Yeah, you SHOULDN'T use the disk M/C, HOWEVER...
This is a simple hydraulic system. The only thing the wheel cylinders know or care about is the diameter and stroke of the pistons in the M/C. ANY M/C with the same diameter and stroke will function exactly the same as far as braking is concerned. Unfortunately, that's the problem. The drum brake M/C uses a 1" bore. The manual disk brake M/C also uses a 1" bore. The power disk M/C uses a 1.125" bore. The larger the bore in the M/C, the higher the required pedal force for the same brake shoe pressure at the wheels. The power M/C can use a larger bore due to the power assist that lowers required pedal pressure.
Old Sep 6, 2012 | 02:33 PM
Tony72Cutlass'S''s Avatar
I just installed a new AC-Delco 4-wheel drum master cylinder.
New shoes, springs, cylinders. The whole deal.
My brakes work great and stop on a dime. I dont know why everyone wants to change to disc brakes so badly.
Old Sep 6, 2012 | 06:29 PM
+1.
I've had plenty of cars with drums all around. As long as they're maintained, they work great.
Though I do like discs a bit better, it's not worth the large amount of effort, time, and money it takes to change a car over.
Old Sep 6, 2012 | 08:19 PM
Amen Eric and Tony
mbat
Brakes/Hydraulic Systems
Apr 12, 2021 07:40 AM
lowkey235
Aug 3, 2012 11:57 AM
Moose2
15
Oct 14, 2011 12:01 PM
denf221
Nov 16, 2010 02:04 PM
54olds
Dec 16, 2007 06:52 AM
