master cylinder question
brakes gave out on me this weekend (72 cutlass supreme) I discovered the master cylinder leaking from underneath, is there a gasket between the cylinder and booster or do I just have bad cylinder?
To answer the original question, yes there is a gasket between the M/C and the booster, but the purpose of that gasket is to seal the booster. As noted above, the M/C pistons have their own seals and there should be no brake fluid leaking out the back of the M/C. Time for a new one.
