Master Cylinder Conversion
Old May 8, 2023 | 06:15 PM
rthuck's Avatar
I have a 1966 Cutlass with a single master cylinder and I would like to convert it to a dual reservoir. Is there a parts supplier that sells a kit to make the changeover or at least a list of the parts needed to do the job?
Old May 9, 2023 | 05:32 AM
If you want to convert to a dual chamber master cylinder I suggest getting an OE one off of a later model Cutlass. I'm not sure what parts you would need though. Master cylinder, vacuum booster and proportioning valve at the least.
Old May 9, 2023 | 06:37 AM
It's not quite that easy. The pushrod between the booster and M/C is longer on the single circuit master cylinders and won't work if you try to simply bolt a 1967 M/C to a 1966 booster. Yes, you can swap the combined 1967 booster and M/C onto a 66 and avoid this problem, but again be aware that the 1964-66 booster is 9" and the 67-up booster is 11". This is why 1967 442s used a single notched valve cover on the driver's side. It's not an issue on a small block car. I'll also add that there is no proportioning valve used on the four wheel drum cars, just a distribution block that really only serves to house the differential pressure switch that illuminated the BRAKE light if you have a leak.
I like to use the 1962-66 Cadillac master cylinder, which is dual circuit but configured for the long pushrod on these cars. It bolts directly to the original booster with no mods required. RAYBESTOS MC36373, about $71 at RockAuto.
Old May 9, 2023 | 11:15 AM
Run to Rund's Avatar
If manual drum brakes, here is the original 1967 setup:
Old May 11, 2023 | 05:45 AM
rthuck's Avatar
I appreciate your responses and I'll look into it more. The car is 4 wheel drum with power brakes.
Old May 11, 2023 | 06:23 AM
Thanks for the explanation Joe.👍
Old Jan 13, 2024 | 02:41 AM
Tri-Carb's Avatar
When you use a 67 manual dual master to replace a single manual master on a 66 442, will a 67 line complete the hook up? Does anyone sell the complete conversion kit?
Old Jan 13, 2024 | 06:29 AM
Unless you are changing the power booster you can't use a 67 master cylinder on a 66. Go back and read post #3.
Old Jan 13, 2024 | 08:40 AM
Tri-Carb's Avatar
The 66 does not have power brakes so #3 is not applicable regarding my line or complete conversion question.
Old Jan 13, 2024 | 08:45 AM
Then you're fine. A brake line kit for a 1967 with manual drum brakes will work, assuming you install the factory distribution block in the stock location.
Old Jan 13, 2024 | 08:58 AM
Tri-Carb's Avatar
Thanks. The 66 distribution block is in the factory location. Does a 67 use the same distribution block in the same location?
Old Jan 13, 2024 | 09:07 AM
No, which is why I mentioned it.
Old Mar 7, 2024 | 09:15 AM
Jeff Hiles's Avatar
i agree try to go oem bought a kit for my 64 from inline unfortunatly i let it sit for a year before installing,no warr got lucky the rod was the adjustable clevis the lines and block were difficult the masrer cylinder lid gasket was too big and wouldn't seal an old gm lid worked better i still carry brake fluid very disappointed
Hdhomer1969
Brakes/Hydraulic Systems
Mar 19, 2022 01:46 PM
Sleepybeaver
Nov 7, 2016 12:29 PM
ilandtime
Mar 10, 2014 09:25 PM
kds 69 442
Oct 23, 2013 02:40 PM
Mr Shifty Sidney
Jun 12, 2013 12:06 AM
