Cutlass Master cylinder interchange
Old Mar 19, 2022 | 12:17 PM
Hdhomer1969's Avatar
Anyone know if the 67-69 disc/drum master is interchangeable with the 70-74 master? I have a master for a 70 will I be able to use it on my 69 Cutlass? Is the only difference between the 2 the reservoir style?
Old Mar 19, 2022 | 01:20 PM
The only thing that matters functionally is the piston bore. If they are the same bore, you can interchange them. Power disc brake M/Cs for 1967-72 should all be 1 1/8" bore.
Old Mar 19, 2022 | 01:46 PM
Thanks Joe!
That’s what I was thinking. Yes, they are both 1-1/8” for power brakes.
ilandtime
Brakes/Hydraulic Systems
Mar 10, 2014 09:25 PM
Mr Shifty Sidney
Jun 12, 2013 12:06 AM
Steve69
Sep 6, 2012 08:19 PM
texasred
May 1, 2012 08:48 PM
scrappie
Nov 18, 2007 06:41 PM
