How do you get to those plugs?
Old Sep 30, 2006 | 09:47 AM
sbs4332's Avatar
I tried to change the spark plugs on my 1988 Cutlass 2.8 liter, but cant get to the back side plugs. Anybody have the same issues, and if so, how did you get these plugs out? Thanks for any help.
Old Nov 22, 2006 | 03:46 PM
cutroc350's Avatar
To get to the rear plugs dissconect one end of each front engine mount after you make sure you are parked on a level serface. After you remove the mounts you can then tilt the engine foward enough to reach the plugs.
Old Nov 23, 2006 | 05:58 PM
Chumley's Avatar
Boy, and I thought removing the front wheels on my '70 SX to access the rear plugs from over the A-arms was a pain in the butt! Don't know if an '88 would allow you to do that.
Chumley
Old Feb 24, 2008 | 05:50 PM
Redog's Avatar
Gotta climb under the hood and look down the back of the engine.
Works on the Alero
Old Feb 28, 2008 | 02:19 PM
arocars's Avatar
You could also try to access the plugs from underneath the car.
Old Feb 28, 2008 | 02:22 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
R.I.P.
This thread
2006
Old Feb 28, 2008 | 02:25 PM
The_Jeremiah's Avatar
LOL too bad i didnt see this before. because thats why they put the engine mount right on top. there is even a big loop attached to the engine. all that is so you can unbolt the motor and attach an engine lift to it. it will rotate pretty far.
DewChugr
Jul 20, 2015 07:09 PM
bob p
Apr 10, 2015 01:55 PM
skryla
Nov 3, 2011 08:39 PM
jaunty75
Aug 5, 2009 06:05 PM
vista461
Jul 25, 2009 06:01 PM
