Holly vs Rochester
Holly vs Rochester
Some while back I was looking for an answer to my Carburetion problems. I had just installed a rebuilt stock Rochester. I could find no one that could 100 percent get it right. Finally I found an Old Carb Mechanic that refused to work on it and told me to swap the reject (Rochester) for a Holly 350 cfm and plug the emmisions ports except the PCV.
Has anyone tried something like this and if so what did you do about getting the choke correctly connected and adjusted as this is the only reason I'd do the swap since the car starts and runs fine now, that I know not to tap the gas pedel all the way to the floor before turning the key.
Has anyone tried something like this and if so what did you do about getting the choke correctly connected and adjusted as this is the only reason I'd do the swap since the car starts runs fine now that I know not to tap the gas pedel all the way to the floor before turning the key.
Welcome to the site, another person from Southwestern Oregon! Yes, you will find most guys here are happy with Rochester caburators. There's at least one person here who has been rebuilding quadrajets and really knows his stuff. Please post more information and I'm sure we can get you some help. John
1979 vin F, gasoline, stock 260cid V8 with all emmisions pieces inplace and fucntioning. The carb is the Rochester 17059150 M2MC (Thermostate / Choke gets warm air from intake manifold).
The two barrel Rochester from the late 70's is a pretty reliable carb. My first question is did replace the gasket that's between the carb and intake. Also you would want to check the vacuum lines to make sure they are good.
OK, I just saw the info on his summary. You would need an adapter to put the Holley onto his manifold, right? Setting up a Dual Jet is no harder than a Quadrajet. A competent shop should have no trouble with it. Also, the air cleaner "mouth" would be different, so that is another hassle and expense from trying to put on a Holley.
Bernhard
November 12th, 2012 07:05 AM
