help identify these grills
Just checking to see what these originally came on, they are metal.
I was surprised how heavy they where, since i thought they were plastic.
Has anyone ever tried straightening one?
I'll get ahold of you when I get closer to needing them. Car is in the tear down phase now.
Its a 72 "S" but I'm not doing a concourse restoration on it, just building a driver, so I'm not sure what grills I like the look of yet.
If it's a 72 the grills are technically incorrect even though they fit. Your stone shield also likely needs replacing as it looks busted up. I'm sure Scott or others can hook you up with the parts you may need when the time comes.
