help identify these grills
Old Sep 17, 2015 | 02:14 PM
Krom's Avatar
Just checking to see what these originally came on, they are metal.
I was surprised how heavy they where, since i thought they were plastic.
Has anyone ever tried straightening one?
Old Sep 17, 2015 | 02:25 PM
oldspackrat's Avatar
1971 Cutlass Supreme only. They are made of potmetal & usually will only bend once. If you try to straighten them they almost always break.
Old Sep 17, 2015 | 04:03 PM
RetroRanger's Avatar
72 Olds CS
x2 on all of the above
Old Sep 17, 2015 | 04:46 PM
Krom's Avatar
Thanks for IDing them!
I had a feeling on the bold. One is straight, the other is caved in, but not cracked or chipped.
Old Sep 17, 2015 | 05:23 PM
I have some of those grills in stock. Which side do you need? I can get pictures and prices in a day or two.
Old Sep 20, 2015 | 07:21 AM
Krom's Avatar
I'll get ahold of you when I get closer to needing them. Car is in the tear down phase now.
Its a 72 "S" but I'm not doing a concourse restoration on it, just building a driver, so I'm not sure what grills I like the look of yet.
Old Sep 20, 2015 | 07:34 AM
If it's a 72 the grills are technically incorrect even though they fit. Your stone shield also likely needs replacing as it looks busted up. I'm sure Scott or others can hook you up with the parts you may need when the time comes.
Old Sep 22, 2015 | 11:33 PM
s i 442's Avatar
Oldsmobile enthusiast
Since your in tear down mode you should get the right grilles instead and they are light weight plastic.
bainer1290
Mar 24, 2014 09:50 AM
milehigh
Apr 11, 2012 12:07 PM
7D2455
Wheels and Tires
Dec 15, 2011 02:45 PM
Bushbunny62
Sep 19, 2010 07:25 PM
Hairy Olds
Aug 3, 2009 07:14 AM
