fuel pumps
Old Sep 2, 2025 | 07:50 AM
irydasteelhorse's Avatar
fuel pumps
ok fellers...... my 67 fuel pump died. the car was actually still kind of running on 1/2 lb of pressure. so i go get, not one, but two new fuel pumps. hooked up the first and it pegged my gauge at 10+ lbs and over ran my carb. second one form a different parts house, exact same issue, even though they both show they are factory set at 5-7 lbs. whats up with that? bad luck? chinesium parts? the girl at the counter started to blame me for not diagnosing another issue. i told her there is no regulator, just a tank, line, pump, carb. i wanted to tell her ive owned the car longer than shes been alive......whats goin on?
Old Sep 2, 2025 | 08:27 AM
Originally Posted by irydasteelhorse
... chinesium parts
^^^THIS^^^
I've been lucky with the mechanical fuel pump on my 71 98. Probably because I recently replaced it with a good parts store unit that was on my spare 455.
I gave up on mechanical fuel pumps for my 86 Ford F250. I went to an electric.
Old Sep 2, 2025 | 12:50 PM
I had a similar problem years ago and ended up using one of these:
https://www.jegs.com/i/JEGS/555/1591..._DftEXrHIbUWOk
Old Sep 3, 2025 | 09:50 AM
acavagnaro's Avatar
Every new mechanical pump I've used over the past 5+ years has put out waaay more pressure than it's supposed to. The pumps for our cars will all claim they're 'factory set' at 5-7psi and will actually put out closer to 8-10. I've learned you must plumb in a gauge to see what you're actually getting to the carb and, if necessary, you'll need to add a regulator as Fun71 suggests. That will allow you to dial the pressure back to somewhere around 6psi.
Old Sep 24, 2025 | 06:32 AM
sravet's Avatar
FWIW I have a new-to-me '66 Cutlass and started having flooding issues, and found that the mechanical pump was putting out 9psi. The pump isn't new, but I also don't know how old it is. Looks like it's been on there a while.
Old Sep 25, 2025 | 12:58 PM
Taz54904's Avatar
I put in a fuel regulator on my 67 as well. When I swapped out the factory 2 barrel for an Edelbrock 4 barrel, the manual suggested a fuel regulator. I installed it on the inner passenger fender.
Old Sep 25, 2025 | 05:30 PM
i ended up doing the same, an in-line edelbroke regulator. im up n running again. its sad that you cant get quality parts anymore
1of1442's Avatar
I recently replaced my mechanical fuel pump and ended up cutting my steel fuel line and adding a pressure reg.
After a fair amount of online research, my conclusion was, most likely 1 manufacturer for all brands and that a whole batch of pumps were/are manufactured with the wrong spring . Chinamen don’t really care , ain’t no 455 Rockets over there .
Old Sep 26, 2025 | 02:44 PM
Cholp's Avatar
Learning…
allyolds68
Jan 4, 2024 09:49 AM
aggrorider1
Apr 5, 2022 03:55 PM
68_Cutlass_S_Convertible
Aug 15, 2021 08:21 AM
67442nut
May 11, 2014 09:19 PM
67442nut
Sep 18, 2012 01:06 PM
