exhaust
Old Aug 12, 2016 | 12:44 PM
jjborgesi's Avatar
exhaust
Hi all. Anyone ever have trouble getting the rear exhaust pipe over the rear axle? I have a 1971 cutlass with a 455 and I am trying to put a 2 1/2" dia duel system on. Thanks.
Old Aug 12, 2016 | 01:06 PM
You may have drop the shocks and lower the rear end, while getting the car high enough to twist it in there.
Old Aug 12, 2016 | 01:25 PM
Olds442redberet's Avatar
I took out the rear bolt on the lower trailing arm and loosened the front bolt so I could get it out of the way as well.
Old Aug 12, 2016 | 01:36 PM
I've generally found that I can "roll" it in with the car jacked up by the frame, with the wheels hanging, but sometimes you need it to be "way" up in order to get clearance far enough away from the ground.
Jun 3, 2019 11:53 AM
atkinsom
May 29, 2013 06:39 PM
65OldsDelta88SuperRocket
Oct 27, 2011 09:16 PM
Chuck C
Sep 1, 2004 07:37 PM
