Emblem placement
Old May 3, 2009 | 04:59 PM
Chumley's Avatar
Emblem placement
Does anyone have the spec's for the placement of the "Cutlass" fender emblems for a '72 Supreme? The car had all the badges stripped and the mounting holes filled in with bondo before painting it. I want to drill out the holes again before I repaint it and want the emblems in the factory correct location. ( It's hard to get to the inside of the fender where I can feel the bondo with my fingers, short of removing the fender itself) Thanks , Chumley
Old May 8, 2009 | 11:26 AM
Hi Chumley
The easiest way would be to sand the car down properly to metal and the mounting holes will be easy to spot as little round bondo dots. I personally would take the fenders off to do a good job. Usually if someone has already done a bondo job on the car, it's hiding something else too. Really take a close look at the lower fender by the door opening. Because of it's design it traps crud like leaves and such creating a breeding ground for rust. These fenders were not rust proofed when they left the factory either. If you find more rust than you expected by taking the fenders off, it will save you time and money in the long run instead of having to do it all over again.
I'm attaching a couple of scanned images from the Olds Chassis and Assembly manuals. Sorry they are a little on the small size, but they'll give you the general location you're looking for.
Old May 10, 2009 | 06:38 PM
Chumley's Avatar
Thanks Alan, I have the pages from the manuals, they just don't give measurements. It didn't occur to me to sand down the area to find the bondo from the outside. Actually the fender bottoms are in good shape on this car. The only major bondo is in the passenger side door and part of the quarter panel from a once-upon-a-time collision. I guess I'll do the same for the trunk letters. Thanks, Chumley
LIMEGREEN71
Sep 30, 2015 11:56 AM
aliensatemybuick
Jul 30, 2012 07:24 PM
Jolly Green
Jul 29, 2009 01:18 PM
jdana24
Jul 8, 2009 07:35 PM
rsandhoff
Oct 22, 2008 07:14 PM
