Electric Choke
Old May 28, 2021 | 04:05 PM
block727's Avatar
Electric Choke
Good afternoon, I'm trying to find a place to hook up the electric choke to, anyone have any ideas? I tried cutting into the wipers but they stayed on all the time. The guy who had the car before me had it hooked up to the wire coming off of the coil. It never worked since i've had the car .
Old May 28, 2021 | 04:07 PM
2blu442's Avatar
Joe put this sticky together a while back. I found it helpful.
Electric choke wiring - ClassicOldsmobile.com
Old May 28, 2021 | 04:26 PM
4speed455's Avatar
I did the relay triggered off the field wire on the alternator because I have an oil pressure gauge sending unit instead of the dummy light switch.
https://classicoldsmobile.com/forums...ersion-144576/
Old Jun 11, 2021 | 10:46 AM
block727's Avatar
What if I have a Holley carb? The instructions are telling me that because the choke is grounded at the carb and the positive is fused switch power how would I go about wiring this up?
Old Jun 11, 2021 | 01:37 PM
RandyS's Avatar
[QUOTE=2blu442;1345060]Joe put this sticky together a while back. I found it helpful.
Electric choke wiring - ClassicOldsmobile.com[/QUOTE]
It really doesn't matter if it is a Holley, Edelbrock or ???. The wiring concept is the same. Go to post #1 in the thread referenced and it will show you how to wire it up. I used this exact method and it works.
Old Jun 11, 2021 | 02:27 PM
block727's Avatar
So do I still ground the choke since it does have a ground on the actual choke along with the power feed meaning do I still need to wire it into the alternator and if so I have two wires there which one do I splice it into? I'm only asking because I notice the electric choke on the quadra jets only has a power feed so you have to ground it elsewhere.
Old Jun 11, 2021 | 03:06 PM
RandyS's Avatar
Yes, you still have to ground the choke to complete the circuit. A pic of the wires you are referring to will help us help you.
Old Jun 11, 2021 | 03:07 PM
The QJet choke is grounded through the body of the carburetor. If your choke coil has a ground lead, just connect it to the intake manifold, carb screw, etc at a convenient location.
Here are some pics I found on the web:
ELECMAN
Mar 12, 2024 11:45 AM
oldolds88
Feb 5, 2017 07:38 PM
cfair
Mar 22, 2013 09:43 AM
mp71conv
Jan 21, 2009 02:28 PM
justinj
Nov 5, 2008 06:07 PM
