Diesel oil pan question
I have an opportunity to buy a 350 GAS engine that has been retrofitted with a Olds diesel oil pan to make it fit in an 80 Caddy Eldorado. I'm looking to put this engine in a 77 Cutlass. Do I need to be concerned if this pan will fit the chassis or not?
Thanks in advance for any info.
Mark
Mark
Mark
Mark
diesel oil pan
it is different because it's from a diesel,it's 7 quarts.it will clear the crossmember no problem but it will hang down below the crossmember and could be a ground clearance issue.
Here's a Toro pan:
Here's a pan from a 1981 RWD diesel:
And here's a stock pan from a 455, which looks AMAZINGLY like the diesel pan:
The extra oil capacity in the diesel motors is NOT in the pan, it's in the external oil cooler.
Yeah, I've been finding pictures of diesel pans and non-diesel pans and they look too close for me to know.
I appreciate both you guys weighing in though. My biggest unknown was whether the pan would clear the A-body chassis.
diesel oil pan
not sure why we are talking about the similarities between a rwd diesel pan and a big block pan,they have nothing to do with a fwd diesel pan,the fwd pan pictured is not from a 1980 eldo with a 5,7 diesel,it's more likely from an early 70's toro.I can guarantee that the fwd diesel oil pan will hang down considerably below the crossmember. I've done it ,have you?
KRICHEN922
Dec 5, 2009 09:39 AM
