Changing to Sports Steering Wheel
Old Mar 12, 2011 | 10:23 AM
Joffroi's Avatar
Runner
I want to eventually make the swap from a original steering wheel in my 70 SX to a sports steering wheel. If I have the new steering wheel and hub (not worried about honking now), is it just as easy and unscrewing my current wheel and screwing in the 4 spoke?
Old Mar 12, 2011 | 11:35 AM
rocketraider's Avatar
Oldsdruid
If you have the wheel and hub, yes. You need a steering wheel puller to get the current one off, otherwise you risk damaging the collapsible steering column if you beta and hammer it to get the old wheel off.
The old wheel will have an alignment mark on the hub that match marks to one on the steering shaft. Not sure if the repro sport wheels have that. If not you may have to experiment a little to get everything installed right so steering wheel spokes align correctly
Go ahead and get the sport wheel horn pigtail and install it while you're about it. No point in doing the job over. Besides- you never know when you might need that horn.
Old Mar 26, 2011 | 02:50 PM
Joffroi's Avatar
Runner
Are part stores usually generous to let you borrow a steering wheel puller?
Old Mar 26, 2011 | 04:25 PM
That I don't know, but they are cheap to buy.
Old Mar 26, 2011 | 05:06 PM
Joffroi's Avatar
Runner
Wow, I didn't realize they were only $20. I took off the cover of my current wheel to look around. Is it as easy as just using the puller on the big bolt (the white one in the picture), popping off the wheel and then putting the new one and then re-bolting?
Then for my own reference, what are the empty red and yellow sections for, and then what about the blue one too?
Old Mar 26, 2011 | 07:14 PM
In answer to question #1, yes, #2 I never bothered to ask!
Old Mar 26, 2011 | 07:24 PM
Lady72nRob71's Avatar
red and yellow are for the pullers stationary bolts. White for puller rotating bolt. Blue is for horn contact.
Old Mar 26, 2011 | 07:54 PM
2blu442's Avatar
Several years ago I dismantled a steering column with the sport wheel and I took photos of the steps. I've reversed that order starting from where you'll have pulled the standard wheel. I'm not sure the alignment mark other members mentioned were correct on this column, but you can see the dash they're talking about. Check out the photos and let me know if you have any questions.
Once you remove your standard steering wheel it will look like this
Then you'll need to put your hub on and snug down the center nut
Next, use the fastening screws to attach the sport wheel
After that insert the horn contact spring, pin and black plastic ring
You can see the hole to put it in near the 3:00 O'clock position
Bolt on the horn contact with the "L" tab underneath it over the contact spring.
Finally clip on the horn button, hopefully getting the rocket straighter than my picture! P1010213.jpg
Old Mar 29, 2011 | 02:06 PM
Joffroi's Avatar
Runner
I successfully change my steering wheel! Now I just need to get the horn cap. Still an improvement. I've also typed up a tutorial with pictures. Beware, my car slightly electrocuted me while doing this lol. The story is all in the tutorial.
http://www.oldsmobilecentral.com/201...oldsmobile.php
Thanks for the help again.
dan1s
Dec 27, 2023 05:01 AM
jensenracing77
Jun 26, 2011 02:19 PM
crazy'boutOlds
Feb 1, 2011 09:49 AM
yeahbuddy
Sep 24, 2010 09:30 AM
mvonhobe
Jul 28, 2007 04:32 PM
