Can't get the new fuel pump on.
So the new pump is engaging the cam and needs alot of force to get it to sit flush against block so i can line up the hardware to lock it down. It's a bit to much for me to hold with one hand and search for holes with the other. Would one normally advance the cam that drives fuel pump for ease or is this one of those curse and knuckle bust till you get it things
OK. That leads to my next question- I've never rotated the crank before- Can you describe the process? It is something i was planning to do as well with a little mystery oil in the spark plug holes before I got to actually starting the car. Do I need a giant socket to fit over the nut that is in the center of the bottom pulley? BTW- I can't thank you enough for your knowledge- i would not be able to brig this car back without this great knowledge.
You can move it either way, but counterclockwise may loosen it. If so, re-torque it when you're done. (Stated another way, try going clockwise so you don't have to re-torque it.)
Okay, here's what you do:
Measure the actual circumference of your rear tires and check your rear end ratio.
Calculate the number of feet-per-revolution in 4th gear.
Mark out a course and have a buddy push your car along it for a distance of one revolution.
Walk alongside the car, pushing the fuel pump into the hole as your buddy pushes it.
Be sure to have both bolts ready in your hand.
1986cutty
October 8th, 2020 03:07 PM
MDchanic
April 6th, 2013 05:57 PM
Nor Cal Andy
March 29th, 2012 07:27 PM
2doorjunkie
October 26th, 2011 10:49 AM
