A/C to Non A/C conversion, Help
Old Oct 8, 2009 | 05:02 PM
oldsguy71's Avatar
Has anyone done this? If so it is pretty simple? I am starting to acquire parts for the swap and waswondering if i need to know anything special.
Old Oct 8, 2009 | 10:57 PM
Willidog's Avatar
Official Tire Kicker
What kind of car?
Old Oct 9, 2009 | 03:53 AM
Welcome
Welcome aboard
And what he said.
What year/make??
Old Oct 9, 2009 | 04:27 AM
oldsguy71's Avatar
ac conversion
I have a 71 Cutlass Supreme that had no heat or a?c when I bought it. I think after doing a little research it seems as though it would be easier to reinstall a/c. But it will be way expensive I think?
Old Oct 9, 2009 | 07:28 AM
citcapp's Avatar
Do you have the blower motor and heater core? if you do you can buy an AC delete unit and just go with the heater, otherwise its junk yard time.
Good luck
The firewall cutouts for A/C are different and larger than those for heat-only. As a result, the heater box will not cover them. Your options are to either weld up the holes (the complete firewall is now available as a repro) or to get an aftermarket heat-only firewall box that is shaped to replace the A/C box.
Old Oct 9, 2009 | 07:31 AM
Oldsguy's Avatar
Past Administrator
Good luck however you end up going. Welcome to CO.
Old Oct 9, 2009 | 07:39 AM
Clarification please
Having a hard time understanding exactly what you're looking at. When you say it has no heat or AC, do you mean that the fan is not blowing? Or do you mean that when you slide the dash control from Cold to Warm that there's no change in temp? You could be looking at something as simple as a replacement dash switch, thermal limiter switch, need a freon charge, or a disconnected cable behind the dash. After that it gets a little more complicated. If you have no heat, you might also have a blocked heater core, not uncommon on an older car.
Old Oct 10, 2009 | 07:11 AM
oldsguy71's Avatar
71 cutlass no a/c
I decided to go back to air conditioning. The car had everything removed when I bought it so I will have to find EVERYTHING!!!!!
Old Oct 11, 2009 | 11:53 AM
TRIXXTERR's Avatar
Yeah the Title had me confused too.. I good luck finding all the parts needed. sounds like one hell of a job.
Old Oct 11, 2009 | 07:45 PM
oldsguy71's Avatar
Yeah thanks I hope I can Find everything!!!
mkenny
Nov 29, 2014 12:04 PM
e.cast728
Apr 7, 2014 04:14 AM
kpl70sx
Non-Olds Engines
Dec 3, 2010 08:57 PM
507OLDS
Sep 17, 2010 06:32 AM
I8AF85
Feb 6, 2009 01:07 PM
