Broken Rotor Studs
Old April 27th, 2016, 03:29 PM
  #41
Octania's Avatar
No, it's actually torque-limiting. The torsional wrap-up of the stick (or long extension) absorbs the torque from the impact wrench. If the impact wrench were continuously rotating, the sticks wouldn't work - once you wrapped them up, the torque would again be transmitted to the nut (until the stick broke). Since the impact wrench has discrete impacts, so long as the angular deflection of the wrench is less than the wrap-up of the stick, the nut will not tighten further.
Great explanation Joe P.
Now I trust that device
The longest extension I have used is the 4-ft unit I made for trunk latch removal via rear seat. The longest I have used that twists and bounces is a 12+12+6 or so plus a swivel socket for the trans to engine bolts from waaaay back where you can swing a ratchet.
Octania is offline
Old April 28th, 2016, 05:53 AM
  #42
As another example, I've run into this phenomena when stacking extensions to access a hard-to-reach nut. Specifically, these would be the down pipe-to-manifold nuts on my truck. Takes three 3/8" drive long extensions, a deep socket, and the 3/8-to-1/2 adapter on the impact wrench. The slop in all those square drive joints (not to mention twisting the 3/8 drive extensions) really eats up the rotary travel in the impact wrench.
joe_padavano is offline
jdana24
April 28th, 2014 12:58 PM
fast442
July 13th, 2012 10:23 PM
bgarrett
February 25th, 2012 11:49 AM
Z3d
Ninety-Eight
December 15th, 2009 02:17 PM
D Appeldorn
May 9th, 2007 06:10 AM
Quick Reply: Broken Rotor Studs
