1970 Delta 88 disc brake rotor needed
Old Feb 1, 2008 | 07:16 AM
bgarrett's Avatar
I was 40 miles from home on a Sunday in a very small town when my daily driver started running hot.
I pulled into a gas station for water. It was closed of course because its Sunday in a very small town. But the water hose was working and while I was adding water I saw that I had lost the fan belt for the water pump.
Hmmm, small town, Sunday, every store closed.....an old black guy stopped in the 1964 Chevy pickup that he has been driving for 33 years and offered me a used belt that he had at home.
Sure enough he had one that fit and really saved the day.
I would like to do something for him.
He needs a front brake rotor for his 70 Delta 88 and we cant find one.
I was told these cars came with drum brakes but there was a disc brake option--don't know if its true.
If you have a replacement rotor I'd like to hear from you Thanks
Old Feb 1, 2008 | 10:04 AM
Rotors for the late 60s and early 70s B bodies are near impossible to find. If you do a search on our website you will find people with similar problems. I don't know where you can get them.
Old Feb 1, 2008 | 10:12 AM
bgarrett's Avatar
thank you
Has anyone considered using spray-metal (powdered metal sprayed at hi temperature) and then turning them down?
Old Feb 1, 2008 | 12:49 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
There's a boneyard outside of Los Angeles that has a couple of these cars. Where are you located?
number for the yard is: 909 877 6934
Old Feb 1, 2008 | 04:36 PM
Modern Motoring's Avatar
Originally Posted by bgarrett
thank you
you're kidding right ?
Old Feb 1, 2008 | 06:06 PM
bgarrett's Avatar
I learned about it watching guys in the machine shop repairing parts.
Its a great process for building up worn crankshafts and might work for rotors
Old Feb 1, 2008 | 07:18 PM
88 coupe's Avatar
Junior Member
........ Has anyone considered using spray-metal ........
http://www.corrosion.com/thermal.html
http://www.corrosion.com/thermal-sec5.html
Norm
Old Feb 2, 2008 | 06:49 AM
bgarrett's Avatar
Partstrain lists this disc. Is this somehow invalid???
http://www2.partstrain.com/store/?Ne...294966722+6854
Powerstop Front Left Brake Disc - Cross Drilled
1969-1972 Oldsmobile Delta 88
Cross Drilled Front Left (Driver's Side) Brake Disc, Efficiently Displace Heat, Running Cooler Provides Exceptional Stopping Power, Reduces Brake Fade, Vented, For Best Results Use With Powerstop Brake Pads!!! Sold Separately
Fit Note: Jetfire.
Type: Cross Drilled
Old Feb 2, 2008 | 08:13 AM
Looks like you found something of interest.
Old Feb 2, 2008 | 10:02 AM
That might be worth looking into. However, you might want to make sure the company guarantees that they fit your application. It would suck to spend a bunch of money and then get a part that doesn't fit.
Old Feb 25, 2012 | 11:49 AM
mpolds's Avatar
1970 OLds Front ROTORS
I have some (not many) N.O.S. Front Rotors for the 1970 OLDS FULL SIZE. also -- a couple last ++ Asbestos ++ Pads -- so you don't rip this ROTOR to smithereens, because -- yes -- they are IMPOSSIBLE to find NEW on planet earth......
Best to call me --- Craig -- 516 - 485 - 1935.... New York...
Mocephus
Oct 1, 2021 09:45 AM
akins2000
Feb 14, 2012 01:09 PM
akins2000
Jan 26, 2012 02:42 PM
akins2000
Jan 26, 2012 02:25 PM
bobb
Brakes/Hydraulic Systems
Oct 13, 2010 04:23 PM
