85 cutlass power lock diagram
Old Aug 7, 2006 | 07:36 AM
olstoro's Avatar
Hello,
if anyone knows where i can find the power lock wiring diagram on a 1985 cutlass 4 door....please help!
none of the locks seem to work.... all of the fuses are fine.
thank you in advance...
Old Aug 7, 2006 | 09:53 AM
POKANOKET's Avatar
The web site ahdol.com has wiring diagrams that start at $6.95. The web site is www.ahdol.com
An interesting article on adding power windows to a previously manual crank only F body can be found at: http://www.p71interceptor.com/thirdgen/powerwindows/
Good Luck
Old Aug 7, 2006 | 10:18 AM
ozoneblue's Avatar
Cool Power locks
Check the switch for power with test light .I repair alot ofthem .broken wires between door & post They also work off of a reversing ground between switches .Should be on same circuit as dome lights & cig lighter
goldie442
Aug 21, 2015 11:01 AM
benjamin247
Oct 1, 2014 07:23 PM
Maverick
Apr 22, 2014 05:04 AM
randomarrival
Dec 22, 2012 12:28 PM
socalrs
Aug 14, 2012 11:07 AM
