82 Cutlass w/T Top
Old Aug 3, 2007 | 03:16 PM
Siouxman57's Avatar
82 Cutlass w/T Top
I have two Cutlass Supreme's, one is a 82 w/ a V6 (blown) the other a 84 w/ a 307 V8. Will the V8 fit where the V6 was?
Old Aug 3, 2007 | 06:20 PM
crazy'boutOlds's Avatar
You'll need the frame purches for the V-8 motor mounts.
Old Aug 4, 2007 | 06:45 PM
Siouxman57's Avatar
Smile Frame perches?
Are they easily found and installed?
Old Aug 5, 2007 | 05:53 AM
They're one your V-8 car's frame. It's the part were the engine mount bolts too.
Old Aug 5, 2007 | 09:06 AM
Siouxman57's Avatar
About the rest
What about everything else? Transmission, drive shaft and thr computer and wiring?
Old Aug 5, 2007 | 05:25 PM
I'm pretty sure you'll have to switch all of that as well. If I recall, The V-6 starter is on the opposite side as the V-8, but I could be wrong. I'm going to pm you a web site that make make the transition a littler easier for you.
GoBigRed
Brakes/Hydraulic Systems
15
Oct 5, 2015 01:00 PM
cjprm
May 19, 2011 09:17 AM
Olds luvr
Dec 2, 2010 08:26 AM
1983oldsmobiledelta
Body work
Sep 19, 2010 07:15 PM
Jamesbo
Jan 21, 2010 05:23 AM
