72 Cutlass fender molding clips
Old Jan 2, 2012 | 05:13 PM
TenMidgets's Avatar
Does anyone know what clips are required to mount the fender molding on my Cutlass? I have two round holes there as seen in the pic below but want to make sure I buy the right clips and there are so many out there.
2blu442 has one for me but I'll need to find the clips.
Thanks!
Bill
Old Jan 2, 2012 | 06:39 PM
Originally Posted by TenMidgets
Does anyone know what clips are required to mount the fender molding on my Cutlass? I have two round holes there as seen in the pic below but want to make sure I buy the right clips and there are so many out there. 2blu442 has one for me but I'll need to find the clips.
Thanks! Bill
Bill have a look at this link. It shows how the molding is mounted. This is from the 71 Assembly Manual, which is exactly the same as the 72. Look at page 10 of 25 (figure 3). It shows the molding, clip and nut.
http://wildaboutcarsonline.com/members/AardvarkPublisherAttachments/9990376413504/1971_CUTLASS___442_ASSEMBLY_MANUAL_-_SECTION_11__Part-2.pdf
Not sure who has the clips to hold this. I was looking at this site http://www.thefastenerwarehouse.com/...fasteners.html and they seem to have similar clips but are listed as Chrysler or Ford. Maybe give them a call and ask if they will work? In a worst case scenario you could always go with a plastic clip and just rivet it to the car, then snap the stainless over top. It will work that way too.
Old Jan 2, 2012 | 07:02 PM
TenMidgets's Avatar
Thanks again Allan for the great info.
Would these do the trick if I add the nut?
http://www.opgi.com/p/fasteners-clip...88/A10220.html
Old Jan 2, 2012 | 07:13 PM
According to the product specs on their site, it should work. Double check the molding width. These are 3/4" - should work fine. Only if you're going to use these? I'd just use a pop rivet to hold them. Then you don't have to take out the inner fender liner to get access to the back of a fastener and put on the nut.
Rivet goes in the narrow slot, not the big opening. Once these are in place, you 'snap' the trim in place. Start either top or bottom and hook it over the fastener flange. Give it a smart hit (palm) to lock the other flange onto the clip. Good thing about these is that you will have spares, and they're easy to work with. I like rivets better because if you need to replace the fastener you just drill out the rivet head and the rivet falls out from inside/ falls on the ground.
Billb442
Feb 14, 2014 05:29 PM
jaunty75
Dec 20, 2012 04:20 PM
1968Cutlassfallbrook
Dec 13, 2010 06:30 PM
ctrain22
Body work
Jul 29, 2010 12:26 PM
Threejdsolds
Dec 11, 2008 09:22 PM
