1971 cutlass w A/C
Old Dec 27, 2008 | 02:40 PM
spherion1's Avatar
1971 cutlass w A/C
I have a heater/ A/C problem. The diverter door on the housing below the dash won't open to allow air through. I recently replaced the upper and lower dash so could be I inadvertently knocked something loose? Is that door manually controlled via a cable or vacuum controlled? I dont know how to diagnose the problem. The blower works on all 3 speeds, just no air flowing through the vents??? May have a controller problem? And Thank you! This is my first message on a forum so if I dont make sense then let me know. thanks
Old Dec 31, 2008 | 06:43 AM
spherion1's Avatar
Heater/Ac Problem
two days of trial and error produced the answer. The system is vacuum controlled, two lines from engine through firewall had been switched on controller. one goes to water valve, other to vacuum canister on firewall.The actuator door now works perfectly, all air flowing..had to find a schematic for the vacuum system to figure this out. Thought I would post the solution should anyone encounter a similar problem. Thanks.
Old Dec 31, 2008 | 07:16 AM
gearheads78's Avatar
car guy
Glad you got it figured out. Little mistakes like swapping lines are hard to find and will drive you crazy. I know I've done it too.
79MKII
Jul 31, 2015 04:42 AM
Gotvette?
Jan 9, 2015 06:42 PM
70olds455
Sep 11, 2011 03:52 AM
egknz
Oct 26, 2009 06:06 PM
D. McHenry
May 5, 2006 03:23 PM
