1966 Cutlass-Lost Ignition Keys, Switch Help
Old Mar 4, 2014 | 11:28 AM
txrob779's Avatar
The Noob Messiah
Howdy fellas,
I searched and found a good thread on "How to Change the Ignition Switch" with the keys and a paper clip but I have LOST my keys. I have the whole switch out of the dash sorta hanging but man it is a back breaker for a big guy like me to crawl in there to get to it. I have no clue what the trick is to release those 3 prongs so I can buy a new ignition and trunk keys (I have the trunk open already). There has to be a trick to get this switch disconnected and I have just wore myself out trying to get the switch and wiring where I can even get my hands up IN that dash much less maneuver some **** around LOL . If you have a procedure I would greatly appreciate it.
Old Mar 4, 2014 | 11:57 AM
Yeah. Assuming the locks haven't been changed, take off the inner door panel, remove the door lock cylinder (pull out the horseshoe spring clip), and read the four character code stamped in the side of the cylinder. The door and ignition keys are the same for 1966. You can either take this code to a locksmith or PM me with it and I can cut you a new key for a nominal cost. Same for the trunk cylinder. Remove the two screws on the retainer, pull the cylinder out, and read the code on the side.
Old Mar 4, 2014 | 12:13 PM
txrob779's Avatar
The Noob Messiah
Never mind I got it...holy crap you should have seen me all pretzel-ed out in that car...LMAO. I am gonna have to really look over the wiring to make sure I dont set a fire when I attempt to start him up...wow;
Now I need an ignition switch-key and trunk lock set that are a pair or hell a quad for all 4 lock sets...SEARCH time.
txrob779's Avatar
The Noob Messiah
Sweet please stand by....
Old Mar 4, 2014 | 12:56 PM
txrob779's Avatar
The Noob Messiah
Oh man....lemme guess...the doors and the ignition are the same key and the trunk is another? Great that means I get to try to remember how to get that damn e-clip off the window crank. I have an e-clip remover tool, I just gotta remember how to executed the removal....Man getting old sucks LMAO but my tool is not a door panel e-clip remover, that much I know LOL.
Old Mar 4, 2014 | 01:07 PM
Old Mar 4, 2014 | 01:39 PM
txrob779's Avatar
The Noob Messiah
Yeah Joe...I gotta play it smart and go to damn Autozone and get a $6.47 tool....I will send u you code a bit later.
Thanks again. The internet is greatness.....(woot)
Old Mar 4, 2014 | 05:42 PM
66400's Avatar
Take a piece of coat hanger wire, bend a 90 degree angle to form a 1/4 inch hook and you can use it pull the the C clip off.
Henry
Old Mar 5, 2014 | 03:50 AM
Ranzan's Avatar
Getting There
use a small towel and work it back and forth over the c clip … pops off every time no tool needed
Old Mar 5, 2014 | 05:06 AM
txrob779's Avatar
The Noob Messiah
I tried that, twice each with 2 different towels,,,failed :facepalm:
See I have to accomplish something here. I have to practice working in this car, not getting as pissed, not cussing as much and not tearing **** up as much LOL, So far I need a LOT more practice. However, I have stopped a few times, chilled out and came back to it later and got it done w/o tearing anything up so that's a positive. I will try a towel again today.
Thanks so much for the suggestion
Old Mar 5, 2014 | 06:07 AM
txrob779's Avatar
The Noob Messiah
Got the passenger side off WOOT with a towel. Cool!! Keys coming next...cool
Thanks Eric
Old Mar 5, 2014 | 06:16 AM
One step closer Rob.
Old Mar 5, 2014 | 08:41 AM
txrob779's Avatar
The Noob Messiah
Update...thanks to you guys,
Both door panels OFF...lock sets OUT and moving forward....greatness
denf221
Sep 14, 2023 02:41 PM
jon69olds
Dec 29, 2014 07:09 AM
runnin350
Feb 2, 2014 06:37 AM
meanmechanic01
Aug 2, 2012 10:51 AM
krissiibabii
Aug 4, 2010 03:13 AM
