drop spindles for 1977 delta 88
Ok my question is originally I was told that drop spindles from 92 to96 impalas and caprices would work on my delta 88 since they were both b bodies. Then I was told that s10 drop spindles are the proper fitament can anyone clarify. I've been doing ton of cros referencing and am at a toss up.
If your car uses the 5 x 5" bolt circle now, it's a total bolt-in with all your original brake parts. If your car currently has the 4.75" bolt circle, you need to use the rotors from a 3rd-gen Camaro with the 1LE package. These rotors fit the Caprice spindles, are 12" in diameter, and have the correct 4.75" bolt circle. Unfortunately, if you are running SSII/SSIII wheels, even 15x7, they may not clear the calipers on the Caprice spindles due to the larger rotor diameter.
thank you for that info very informative. so i was on ebay and found cpp classic performance parts located in cali and they had drop spindles part 7981 ds listing said they were for 77-78 caprice. so i called and they said they actually list for 79-81 camaros but told me they cross reference for caprice, impalas as well as my delta 88. well before i ordered i contacted jegs because they stock them also and i asked the same question but they said it strictly shows 79-81 camaros any feedback on this. or can anyone just tell me if there is anything available direct bolt on at all. time is of the essence my car is in the shop currently
Since we're digging up a 7 year old thread...
All of these are dimensionally the same for control arm and tie rod location.
70-78 F-Body
79-81 F-Body (big bearing, but 11" rotor)
73-77 A-Body (11" rotor, small bearing)
77-91 B-Body (5x4.75"= small bearing 11" rotor, 5x5"=big bearing, 12" rotor)
92-96 B-Body (5x5"=big bearing, 12" rotor) Be aware, mid '95 or something they switched to a larger ball joint on police/taxi/limo chassis.
70-78 F-Body
70-78 F-Body
70-78 F-Body
Murco
Brakes/Hydraulic Systems
March 7th, 2013 11:50 AM
69oldsdelta88
May 8th, 2009 02:33 PM
