Best bang for your buck suspension upgrades??
Old December 20th, 2012, 11:22 AM
71murder's Avatar
71 cutlass supreme
455 425hp/500tq
2004r bowtie OD /2200 stall
eaton tru trac posi/3.73
This car will most likely never see the track. Just want a fun street machine that I can have fun with around town and maybe an ocasional road trip. The suspension is BONE stock and i know with all these new upgrades im gonna have a hardtime transfering it to the wheels. What should i add for my goals for the car? im looking to spend no more than 700 bucks. As of now im for sure getting a rear sway bar, all new bushings and new front springs. Any and all advice and ideas are welcome. thanks
71murder is offline
Old December 20th, 2012, 11:45 AM
Originally Posted by 71murder
71 cutlass supreme
455 425hp/500tq
Here's my list, in order of priority:
1) Complete stock rebuild of all suspension parts, front and rear
2) Front and rear sway bars at least 1.25" dia each (with boxed lower rear control arms if needed)
3) Quality gas shocks
4) Performance tires
5) Quick ratio steering box
6) Springs
7) Performance suspension bushings (do this with #1 if you plan to do it)
joe_padavano is offline
Old December 20th, 2012, 11:51 AM
TripDeuces's Avatar
On a limited budget I think sway bars will show an immediate improvement. Especially if you don't have a rear bar on it. A larger front bar would help too. Body mounts and suspension bushings is probably the next step. Either in rubber or poly. The new rubber is superior to the old stuff I hear but I have no first hand knowledge. Considering everything is made off shore nowadays I don't know about the quality. I prefer poly but it's more expensive and can squeak if not kept lubricated. There are some poly bushings that are graphite impregnated to stop the squeak.
TripDeuces is offline
Old December 20th, 2012, 12:08 PM
jfb
jfb's Avatar
I agree with joe you need a complete suspension rebuild. I have also said in numerous posts that I used ho racing parts which is gm a body upgrades. I believe you can still contact them on the web and these parts enhance traction also believe me i know first hand. I have also heard that a fat trans am sway bar fits a bodys for cost cutting purposes. ken crocie runs malibu or ho racing in california and the total cost is usually around now 1200 complete with all parts! front to rear suspension wise!
jfb is offline
Old December 20th, 2012, 01:31 PM
For $700 you can add a rear sway bar and replace bushings, all the front end parts with new moog parts and a set of springs front and back, if you do the work yourself.
oldcutlass is offline
Old December 20th, 2012, 01:50 PM
stevengerard's Avatar
I'd work on your brakes, how are those set up. I noticed a big difference when I upgraded shocks, I changed the bushings to polyurethane as well and actually feel for a cruiser they are too harsh.
Biggest difference I noticed was going from 14" SSIIs to 15" SSIIs
stevengerard is offline
Old December 20th, 2012, 02:57 PM
Let me reiterate what I said in my prior post. The best sway bars, springs, shocks, and tires in the world won't matter if the fundamental suspension parts are worn. FIX THEM FIRST!
Now, if you carefully inspect your suspension and find it is not worn, great, save the money. If the parts are original, it is unlikely that they will not be worn. Even stock replacement parts are better than nothing. If you do plan to upgrade bushing, now is the time to do them, however. Also be sure to check all ball joints and steering parts, as well as the steering box for slop.
Once you have a solid foundation, THEN spend the money on upgrades. I too was somewhat amazed at $1200 for the HO Racing parts. I've performed similar upgrades for substantially less money.
Old December 20th, 2012, 03:23 PM
jfb
jfb's Avatar
hey there was 1 thing i forget to put in place earlier and that is the 1200 also included heavy heavy duty front suspension, rear arms,no hop bars and air bags if somebody wants a complete suspension plus the bars that are 1 and 3 eights thick by the way this i believe is the way to go overall. I am not trying to misleed anybody. this also includes shocks kyb and custom springs. jfb good luck!
jfb is offline
Old December 21st, 2012, 07:30 AM
hookem horns's Avatar
6) Springs
Joe gives good advice as always. I would consider 3 & 6 part of #1 if worn. On #7, don't go poly unless you want a stiff squeeky ride (my opinion and a slight exaggeration). Check with a local parts store before buying online since freight can get high on heavy stuff.
Also like your plan of looking into the brakes. Have to reign in that new power, especially with how people drive today. Get the existing system in good shape even if you don't do a disk upgrade.
It's a long read, but Rob's post covers the front end in detail.
https://classicoldsmobile.com/forums...t-end-job.html
hookem horns is offline
Old February 10th, 2013, 12:11 PM
my71olds's Avatar
6) Springs
Hello:
How do I find out what is needed for #1? Also can you recommend products for #' 2, 3, 5, 6 and 7
Hoping to start my project this spring.
my71olds is offline
Old February 10th, 2013, 06:42 PM
Rickman48's Avatar
Go to a shop that specializes in alignments - they'll tell you all you need to know, and then some!
Make sure you ask for an estimate only, as you were curious how much to set aside, and they should do it for free -
Rickman48 is offline
Old February 11th, 2013, 05:44 AM
72 Olds CS
RetroRanger's Avatar
Originally Posted by my71olds
Hello:
On my car I just replaced all the bushings and ball joints. Some stuff was original some had been replaced. I took it all apart cleaned and painted everything and then installed all new moog parts. Now I shouldn't have to worry that some part that was good but used will fail shortly.
RetroRanger is offline
Old February 11th, 2013, 07:13 AM
Hello:
To be honest, on a car that's over 40 years old, I would just do everything. You can buy the parts individually from an auto parts store or RockAuto or get a kit from Kanter. The problem with buying kits in "white boxes" is that you don't know what you're getting. Buy them individually and you can specify Moog or TRW or whatever you prefer.
I grab the second gen WS6 Trans Am front bars at swap meets for about $25 each. The rear be aftermarket, since the largest factory bar was 7/8". It's simply a bent piece of steel rod, so just find the least expensive one you can.
Monroe is a good gas shock at reasonable prices. KYB is much better and priced accordingly.
Tires are a personal preference. I like BFGs but there are many equally good performance tires.
Get your stock steering box rebuilt by Power Steering Specialties and have them install the quick ratio gear set.
Springs are also a personal preference and depend on how your car is set up.
Old February 11th, 2013, 06:29 PM
QMaster's Avatar
I would add one tip. If you want flat cornering with a nice ride, use polyurethane for the stabilizer bar bushings, but rubber for the control arms.
QMaster is offline
Old March 5th, 2013, 06:28 PM
Erinyes's Avatar
Found some info on OldsmobileWiki about air bags and traction.
I had no idea this was possible, and figured maybe someone else might be interested too. And if anyone has first-hand knowledge, I'd be extremely interested to hear more!
Suspension Air Bags
Air bags are also called air springs. They are essentially big rubber balloons that fit inside the rear springs (or on top, for the leaf spring vehicles). They preload the suspension similar to air shocks, but are more controllable. You can load the right side harder to plant that tire down firmer, while leaving the left nearly unassisted, to provide fairly even traction left-to-right.
They sit right inside the rear coils and air up to assist the springs. (actually, they resist the springs, making them harder to compress). They act similarly to air shocks, but they leave those mounting points free to put useful shocks in their place. Let's face it, air shocks leave a lot to be desired for control and ride. The air bags can be inflated independently, and allow for preloading the right side of the axle. This effectively puts more weight on the drive tire, making it harder to break loose. Result: instant posi.
Plus, without the air shocks, you can have more axle control and less chance of wheel hop. This is an aspect that makes them desirable even with existing posi's. They install literally in minutes...
They work awesome. There are different versions available. The day I put them on, I took a friend out and tried for hours to prove that I had not changed the open rear to a posi! Gravel, pavement, water, didn't matter, I couldn't break loose! I finally had to unload one of the bags and do a bit of a smokeshow, and that finally convinced him. Very impressive items.
And if you already have an anti-spin or posi differential, definately get a set! I'd actually recommend them highly. In addition to controlling axle movement with the shocks, you can preload the suspension to give equal traction characteristics and control/prevent/reduce wheel hop (i.e. put more power to the ground).
Posi-traction is great, but the ability to load each wheel separately was invaluable. I don't see why it wouldn't be fine on a street car. The driving and ride are not compromised at all. Control of the rear is what you are getting here. Different air pressures and combinations give you different traction results.
Erinyes is offline
Old March 6th, 2013, 05:30 PM
ziff396's Avatar
UMI upper rear control arms with the roto joint made a huge difference in the tightness of my rear suspension after adding the poly bushings first. Rides and handles much better. There is no longer any pinch or bounce when the suspension loads up. Just a thought.
ziff396 is offline
Old August 24th, 2021, 09:20 AM
Phoenix8990's Avatar
It there a link for "Power Steering Specialties" I just see PS Specialists? I tried a variation with no luck.
Steve
Phoenix8990 is offline
Old August 25th, 2021, 11:24 AM
No it's not a parts car!!
Schne442's Avatar
Steve
I believe this is the place, I could be wrong , Joe !!!!
http://www.powersteering.com/
Schne442 is offline
Old August 27th, 2021, 05:41 AM
BradleyScott's Avatar
I was talking with a guy local to here about his car and to get a quicker ratio for the steering, he used a 3rd gen f-body box (Camaro/Firebird). As long as it's a good used unit and not leaking; that's probably cheaper than sending your current one out to be reconditioned and modified.
BradleyScott is offline
Old August 27th, 2021, 06:03 AM
A common one used is the Jeep Grand Cherokee 93-97. I don't know how that compares to the Camaro one but there are a lot of threads about it and many guys have done it for a huge improvement. I did and it was well worth it.
Steve
Old August 27th, 2021, 06:15 AM
This link discussed steering boxes, but if you go to the bottom "related topics" there are more threads about steering boxes.
https://classicoldsmobile.com/forums...radius-151102/
Steve
Old August 27th, 2021, 07:38 AM
allyolds68's Avatar
Steve
I believe 70-72 already have the same ratio as the JGC box. It's usually an upgrade for 68-69. I did it on my 68 and I agree.
allyolds68 is offline
Old August 27th, 2021, 11:47 AM
Well, well, well, I learn something everyday on this site for sure.
Steve
Old August 27th, 2021, 01:31 PM
4R5
4R5's Avatar
Yes the F body box is quicker & firmer, but the internal stops are shorter which prevents you from making a real sharp turn.
4R5 is offline
jag1886
October 14th, 2013 08:25 PM
my71olds
September 15th, 2013 02:56 AM
66ninetyeightls
Suspension & Handling
16
February 23rd, 2010 01:14 PM
BerBer5985
July 9th, 2009 04:58 PM
GoldOlds
June 14th, 2007 10:14 PM
Quick Reply: Best bang for your buck suspension upgrades??
