Worlds largest Engine
Old Dec 11, 2013 | 07:05 PM
Kyle's 77 Cutlass's Avatar
Had to share this. Now that is power, make to tool man $hit himself too
http://jalopnik.com/the-largest-pist...ium=socialflow
Old Dec 11, 2013 | 07:30 PM
billmerbach's Avatar
major noob
Dannnnnnnnnnnnnng
Old Dec 11, 2013 | 07:39 PM
You'd need a taller hood for sure.
Old Dec 11, 2013 | 07:40 PM
Octania's Avatar
The picture shows the pony engine that is used to start the Big One.
Old Dec 11, 2013 | 07:43 PM
coppercutlass's Avatar
Chevy budget Olds powered
2 stroke diesel engines sound gnarly. They can be doing 3k rpms and sount like it's doing 24k rpm lol . I wonder if it's even possible for an engine that big to spin to 1000 rpm. I wonder what kind of power it makes at 1000 lol.
Old Dec 11, 2013 | 07:46 PM
You mean just before it bends a rod?
Notice the lack of counterbalances on the rod throws - this is clearly a very low-revving engine:
Old Dec 11, 2013 | 08:05 PM
Yep, very low rpms. Did you read the no and torque output. Nuts
Old Dec 11, 2013 | 08:07 PM
I wonder the life span of an engine that spins that low of an rpm but puts that much power out .
Old Dec 11, 2013 | 08:14 PM
wel, if you figure that most moden container ships cruise at about 30mph, and assume that they travel on average about 5 days out of every week, that means they go nearly 200,000 miles a year.
If they need a refit about every 5 years, then they're getting their bearings checked and possibly overhauled about every million miles.
That's just a guess, though.
Old Dec 11, 2013 | 08:43 PM
I'm surprised it's a 2 stroke. My weed eater is a 2 stroke gasoline engine. It's a POS. I've heard that there are a number of industrial 2 stroke diesel engines in use.
That is definitely a BIG engine.
Old Dec 11, 2013 | 08:57 PM
2 stroke turbocharged diesel and 2 stroke gas engine are two completely different things.
All truly heavy duty diesels are 2 stroke turbos, as far as I know.
Old Dec 11, 2013 | 09:51 PM
orange442's Avatar
5,608,310 lb-ft of torque and up to 108,920 BHP!!! Now I want to see the dyno that could handle that!
Old Dec 19, 2013 | 08:17 PM
mike's88's Avatar
I thought the stuff I build is big(locomotive engines), v16, each cylinder is 710 cu.inches
Old Dec 19, 2013 | 09:09 PM
That's big itself, what you do. But that engine has the wow factor
Old Dec 21, 2013 | 06:00 PM
76olds's Avatar
Hookers under Hood
Hey Kyle I was looking @ some older threads, I see you were getting rebuild info for your 77 olds from cutlassefi ( Mark ) I believe, Just a ? Did you ship your motor from Manitoba to him in the U.S , what kind of work did you do to it, I'm considering buying a used 350 olds off Kijiji up here and would like to know how it went. Maybe a cost as well would be helpful.
Thanks Eric
Old Dec 24, 2013 | 10:47 AM
Hey 76, he is doing a build for me eventually. I wanted to start early next year but things just weren't in our favor this year. Waiting for 2013 to leave
Old Dec 24, 2013 | 11:31 AM
The GMC -56 and -71 series diesel engines are all two stroke. That's why they have the Roots scavenger pumps on the crankcase.
As for the engine in this thread, these engines and photos have been around for close to 20 years now. The article linked in the first post DOES have some new photos, especially the bent rod, so thanks for providing the link.
Old Dec 24, 2013 | 01:17 PM
your welcome joe. Never imagined an engine to be this big
jkoester122
Wheels and Tires
81
Jun 15, 2017 11:59 AM
F-85 4-4-2
May 25, 2014 01:48 PM
XTREMEGSXR
Wheels and Tires
May 10, 2012 02:30 PM
doc
Wheels and Tires
Jan 25, 2011 01:36 PM
gullwingmd
Ninety-Eight
Jun 18, 2007 08:58 PM
