paint matching
Old Apr 21, 2008 | 11:10 AM
ztim's Avatar
paint matching
It seems advice on paint codes always include a disclaimer saying aging could change the hue. Can't an auto paint store use a hand held spectromiter of some sort to actually go outside and hold it up to the car in places? Then the average reading can be used to mix the paint.
Do places do this already or they few and far between? I have seen this done on a DIY show.
Old Apr 25, 2008 | 02:43 PM
dantana's Avatar
Color matching
There are a lot of places that mix paint that offer color reading but you should be aware that you must have a good sample on a relatively flat panel. Any fine scratching or dullness will throw the color off a lot. All of the paint companies will say they don't guarantee a perfect match that you can paint a panel and it will match the adjacent ones. They are offering a blendable color that can be blended into adjacent panels to attain a match. If you are trying to match a metallic color a lot of other things come into play like paint spraying equipment and technique which can change a metallic colors look. If you can give me an idea of what you are trying to do I may be able to point you in the right direction.
Dan
Old Apr 26, 2008 | 06:28 AM
ztim's Avatar
Thanks. I am trying to get a door painted. An auto body shop wanted to blend the door in with the whole side of the car for around $700. The whole car would cost $2000.
Old Apr 26, 2008 | 06:43 AM
Oldsguy's Avatar
Past Administrator
I think that is the point, to paint a whole car and make more money. But, to be honest, it is much easier than trying to match colors. They probably have fewer unhappy customers from whole car paintings than match/spot jobs.
Old Apr 27, 2008 | 11:56 AM
ztim's Avatar
Thanks, guys. Right now I can't affor a whole paint job. I just need something to make it look at least half way decent from afar.
rktolds
Paint
May 10, 2015 07:59 PM
Johnd
Nov 28, 2013 08:31 AM
LI Olds
Aug 23, 2012 10:00 PM
Al2011
Aug 10, 2011 08:58 AM
sincitycutlass
Mar 7, 2011 08:27 PM
